Additional Tractor Work Light Ideas
/ Additional Tractor Work Light Ideas #1
clee4020
Mississippi
Kubota M9540 HD 4x4
Would like to add 2 work lights pointing forward and 1 or 2 pointing rearward to my Kubota M9540 under my canopy to my ROPS. I wind up feeding cows when I get home from work and the factory lights are almost useless when you stick a roll of hay with FEL. I am leaning towards LED due to the low current draw. I am looking for ideas and especially pics.
I mounted these flood lights ( LED 90-deg flood light ) to my mule and they are plenty bright up close, but would like to have something shine out a little further.
/ Additional Tractor Work Light Ideas #2
How about something like this. They are standard equipment on the B26.
/ Additional Tractor Work Light Ideas #3
The top two rear lights are standard - the bottom two rear lights are one set of the optional work lights available for the B26.
/ Additional Tractor Work Light Ideas #5
The factory front and rear lights (the upper ones) are attached to the plastic roof cover over the FOPS.
You can add four additional work lights - two on the front and another set on the rear as shown in the photo. The optional worklights for the B26 attach to the ROPS.
Lauren
/ Additional Tractor Work Light Ideas #6
This is my setup has worked well for ten years.
The front lights are long tapered beams I forget the specific name.
The rears are flood type
The center rear light is a driving light.
/ Additional Tractor Work Light Ideas #7
Mine, 2 forward and 2 rear plus my revolving light....Mike
These are some great ideas. What king of lights are they? LED? Halogen?...Since I do a lot of bushhogging and other work around near the woods, I don't think it would be wise for me to mount at the front of my canopy (mostly because others use my tractor too and wouldn't be as careful as I would). I'm leaning towards mounting to ROPS under canopy and probably make some sort of protection for them.
/ Additional Tractor Work Light Ideas #9
Mine are just regular incandescent. They've never gone out yet from vibration or damage, the revolving light filament has broken a couple times tho....Mike
/ Additional Tractor Work Light Ideas #10
I used what ever lights come on a Case 580 backhoe. These things are great.
2018 Freightliner M2 106 AWD Altec AA55 56ft. Insulated Material Handling Bucket Truck (A60460)
2018 Freightliner...
Case SV280B (A60462)
2023 HarbinGer V3 Plus 8KW S/A Towable Light Tower (A60352)
2023 HarbinGer V3...
2019 FORD F-250 (INOPERABLE) (A60736)
2019 FORD F-250...
2007 CATERPILLAR 725 OFF ROAD DUMP TRUCK (A60429)
2007 CATERPILLAR...
TRI PAC EVOLUTION APU (A60736)
TRI PAC EVOLUTION...
