Additional Tractor Work Light Ideas
/ Additional Tractor Work Light Ideas #1
clee4020
Mississippi
Kubota M9540 HD 4x4
Would like to add 2 work lights pointing forward and 1 or 2 pointing rearward to my Kubota M9540 under my canopy to my ROPS. I wind up feeding cows when I get home from work and the factory lights are almost useless when you stick a roll of hay with FEL. I am leaning towards LED due to the low current draw. I am looking for ideas and especially pics.
I mounted these flood lights ( LED 90-deg flood light ) to my mule and they are plenty bright up close, but would like to have something shine out a little further.
/ Additional Tractor Work Light Ideas #2
How about something like this. They are standard equipment on the B26.
/ Additional Tractor Work Light Ideas #3
The top two rear lights are standard - the bottom two rear lights are one set of the optional work lights available for the B26.
/ Additional Tractor Work Light Ideas #5
The factory front and rear lights (the upper ones) are attached to the plastic roof cover over the FOPS.
You can add four additional work lights - two on the front and another set on the rear as shown in the photo. The optional worklights for the B26 attach to the ROPS.
Lauren
/ Additional Tractor Work Light Ideas #6
This is my setup has worked well for ten years.
The front lights are long tapered beams I forget the specific name.
The rears are flood type
The center rear light is a driving light.
/ Additional Tractor Work Light Ideas #7
Mine, 2 forward and 2 rear plus my revolving light....Mike
These are some great ideas. What king of lights are they? LED? Halogen?...Since I do a lot of bushhogging and other work around near the woods, I don't think it would be wise for me to mount at the front of my canopy (mostly because others use my tractor too and wouldn't be as careful as I would). I'm leaning towards mounting to ROPS under canopy and probably make some sort of protection for them.
/ Additional Tractor Work Light Ideas #9
Mine are just regular incandescent. They've never gone out yet from vibration or damage, the revolving light filament has broken a couple times tho....Mike
/ Additional Tractor Work Light Ideas #10
I used what ever lights come on a Case 580 backhoe. These things are great.
Toro Zero Turn Lawn Mower (A56859)
Toro Zero Turn...
CFG Industrial H15R (A60463)
CFG Industrial...
CAT Chassis Only (A59076)
CAT Chassis Only...
2013 ORTEQ ENERGY GN182 GOOSENECK HOSE TRAILER (A58214)
2013 ORTEQ ENERGY...
2009 IC Corporation PB105 School Bus (A60352)
2009 IC...
Pat's QH and hydraulic top-link.
Pat's QH and...
