Additional lights on 2305 ROPS
   / Additional lights on 2305 ROPS
I hadn't thought of that, Gator. I'll see if I can find some! I'm also having wiring problems since the wires and bolts go through the same pre-drilled hole in the rops. Any ideas?
John Deere 2305 w/ 200CX FEL & quick hitch power broom.
   / Additional lights on 2305 ROPS #32
Yeah, move the wires!
   / Additional lights on 2305 ROPS #33
gator is describing nylock nuts which is a good choice, available at any hardware store. I can't visuallize what is going on with the wires but any of these should protrude through the rops without a chance for pinching. If you need a new hole for the wire to pass through the rops might make it big enough to fit a rubber grommet.
Ahh...see, the bolt goes from the lights, through the bottom hole with the wires beside it, then out the top hole, while the wires stay inside the rops. I didn't dare drill a second hole for wires because I thought it would weaken the rops. Is a small hole for wires ok to drill? That would be ideal!!
   / Additional lights on 2305 ROPS #35
That's exactly what I did for mine. That extra hole won't hurt anything, but either put some flexible conduit around the wire where it goes into the ROPS, or put a rubber grommet in the hole to avoud chafing the wire.
Sent from my LGL35G using TractorByNet
   / Additional lights on 2305 ROPS #36
I drilled mine as well, two small 1/4" holes will be OK. If you looked at the older post I linked above you'll see that I drilled mine a few times.
HITACHI EX550LC EXCAVATOR (A58214)
HITACHI EX550LC...
2005 GMC Canyon (A57148)
2005 GMC Canyon...
2014 Ford Fusion Passenger Car, 2.5L Engine - Only 90,875 Miles (A56438)
2014 Ford Fusion...
8 TOOTHED BUCKET FOR MINI EXCAVATOR (A58214)
8 TOOTHED BUCKET...
30' E-Z Trail Head Cart (A59814)
30' E-Z Trail Head...
*Selling at Royal Auction Zephyrhills, FL Location* 5 (A59228)
*Selling at Royal...
