Adding teeth to front end loader
/ Adding teeth to front end loader #1
toolmaan
Is there a easy way to add some gripping teeth to a front end loader bucket? Have about a 5 ft bucket and want to do a little bit of digging with it.
/ Adding teeth to front end loader #2
The best way is a removable toothbar. Do a search for "markham" and "toothbar" and you will find hundreds of post's about them.
Markham Welding - Tooth Bar
/ Adding teeth to front end loader #3
What Kenny said.
That link he gave you is a good one.
You can call them and they will get one fit to your bucket. The way they make theirs with a hard cutting edge and teeth with replaceable tips, it's almost not cost effective to try to make your own.
A toothbar from them is well worth the couple hundred bucks they get for them.
Thanks for the info
/ Adding teeth to front end loader #5
If he wanders back in, Spiveyman is our resident expert on installing a toothbar. Only took him a few months to get it installed, bless his heart.
David from jax
/ Adding teeth to front end loader #6
If you order from Markham, they will ask you for the interior dimensions of your bucket. Don't try to second guess the clearance as they will subtract 1/4 inch from the dimensions that you give them.
I'm very satisfied with my markham toothbar. I discarded my JD bar to get it.
/ Adding teeth to front end loader #7
A toothbar is great. I fabbed one up a few years ago and the results were amazing. It used to take me two or three passes to fill a bucket but after the bar I could make it spoil up over the top in one pass. And yeah, I won't spend the time or effort to make one myself again.
bjepple
/ Adding teeth to front end loader #8
So what did it cost and what size did you get?? BG in Iowa
/ Adding teeth to front end loader #9
Several years ago I welded up a tooth bar for my B8200's bucket, using forged steel combine teeth and a 3/8" x 4" bar... it's worked great, and cost me about $50 if I remember right. I posted some photos, which I guess would still be available? If you have a small tractor, one with limited lifting power, like mine, then I think my approach is good, assuming you have time.
/ Adding teeth to front end loader #10
I bought mine from Markham three years ago for $210, 60" bucket.
/ Adding teeth to front end loader #11
Varmint,
Got any pics of that? For that price I may try making one again.
bjepple
/ Adding teeth to front end loader #12
I think the price very reasonable considering all the little detail that you dont have to worry about. Not to mention getting the teeth and shanks from somewhere. I know all this could be make from scratch, but its take time and equipment. For most of us the 200-300 bucks doesn't seem that bad. Then again we do live in an "instant" society.
Wedge
/ Adding teeth to front end loader #13
Not sure how to link, but there are photos of my toothbar project in the "attachments" forum, and you can find them by searching for "varmint". http://www.tractorbynet.com/forums/attachments/31811-bucket-toothbar.html is one link, the other is clost by. I'm not at my home computer, or I'd just re-attach the photos. I got the teeth at a TSC store, maybe $5-6 each (two teeth on each forging). WHIW, I used to live in the Bloomington, IN area- still think it's a nice place.
/ Adding teeth to front end loader #14
I have my teeth welded on permanently because most of my work with the FEL is digging. Once in a while I wish I had my blade alone with out teeth but not often enough to have the teeth removed.
/ Adding teeth to front end loader #15
Gee...when did this become the "Buy It Yourself Forum"?
After I get done putting hydraulics on my '67 Wheel Horse,I'll start on the toothbar.
/ Adding teeth to front end loader #16
Well, ya gotta open your wallet all by yourself....
jb
CHECO GREASE UNIT (A67714)
CHECO GREASE UNIT...
2023 Giant G2500HD Mini Articulated Wheel Loader (A66734)
2023 Giant G2500HD...
PALLET OF HOSES (A68842)
PALLET OF HOSES...
2018 Autocar ACX Xpeditor T/A New Way 31ASL 31yd. Side Loader Garbage Truck (A66736)
2018 Autocar ACX...
2012 HARDEEBILT 827PEQ6 EQUIPMENT TRAILER (A66091)
2012 HARDEEBILT...
2019 CATERPILLAR TL642D TELESCOPIC FORKLIFT (A65056)
2019 CATERPILLAR...
