Adding teeth to front end loader
/ Adding teeth to front end loader #1
toolmaan
Is there a easy way to add some gripping teeth to a front end loader bucket? Have about a 5 ft bucket and want to do a little bit of digging with it.
/ Adding teeth to front end loader #2
The best way is a removable toothbar. Do a search for "markham" and "toothbar" and you will find hundreds of post's about them.
Markham Welding - Tooth Bar
/ Adding teeth to front end loader #3
What Kenny said.
That link he gave you is a good one.
You can call them and they will get one fit to your bucket. The way they make theirs with a hard cutting edge and teeth with replaceable tips, it's almost not cost effective to try to make your own.
A toothbar from them is well worth the couple hundred bucks they get for them.
Thanks for the info
/ Adding teeth to front end loader #5
If he wanders back in, Spiveyman is our resident expert on installing a toothbar. Only took him a few months to get it installed, bless his heart.
David from jax
/ Adding teeth to front end loader #6
If you order from Markham, they will ask you for the interior dimensions of your bucket. Don't try to second guess the clearance as they will subtract 1/4 inch from the dimensions that you give them.
I'm very satisfied with my markham toothbar. I discarded my JD bar to get it.
/ Adding teeth to front end loader #7
A toothbar is great. I fabbed one up a few years ago and the results were amazing. It used to take me two or three passes to fill a bucket but after the bar I could make it spoil up over the top in one pass. And yeah, I won't spend the time or effort to make one myself again.
bjepple
/ Adding teeth to front end loader #8
So what did it cost and what size did you get?? BG in Iowa
/ Adding teeth to front end loader #9
Several years ago I welded up a tooth bar for my B8200's bucket, using forged steel combine teeth and a 3/8" x 4" bar... it's worked great, and cost me about $50 if I remember right. I posted some photos, which I guess would still be available? If you have a small tractor, one with limited lifting power, like mine, then I think my approach is good, assuming you have time.
/ Adding teeth to front end loader #10
I bought mine from Markham three years ago for $210, 60" bucket.
/ Adding teeth to front end loader #11
Varmint,
Got any pics of that? For that price I may try making one again.
bjepple
/ Adding teeth to front end loader #12
I think the price very reasonable considering all the little detail that you dont have to worry about. Not to mention getting the teeth and shanks from somewhere. I know all this could be make from scratch, but its take time and equipment. For most of us the 200-300 bucks doesn't seem that bad. Then again we do live in an "instant" society.
Wedge
/ Adding teeth to front end loader #13
Not sure how to link, but there are photos of my toothbar project in the "attachments" forum, and you can find them by searching for "varmint". http://www.tractorbynet.com/forums/attachments/31811-bucket-toothbar.html is one link, the other is clost by. I'm not at my home computer, or I'd just re-attach the photos. I got the teeth at a TSC store, maybe $5-6 each (two teeth on each forging). WHIW, I used to live in the Bloomington, IN area- still think it's a nice place.
/ Adding teeth to front end loader #14
I have my teeth welded on permanently because most of my work with the FEL is digging. Once in a while I wish I had my blade alone with out teeth but not often enough to have the teeth removed.
/ Adding teeth to front end loader #15
Gee...when did this become the "Buy It Yourself Forum"?
After I get done putting hydraulics on my '67 Wheel Horse,I'll start on the toothbar.
/ Adding teeth to front end loader #16
Well, ya gotta open your wallet all by yourself....
jb
