Adding rear hydraulics to L2250
   / Adding rear hydraulics to L2250
I'm trying to wrap my head around this. It's tapping into a pressure port on top of the 3 point, going thru an open center valve on the fender and returning back to the same port on the 3 pt? Or am I missing something? Here's what mine has at the same place.
Just trying to figure out how to tap into this?
   / Adding rear hydraulics to L2250 #44
Based upon what LeeJohn said a while back about an oblong O ring under the cover, I believe under the plate you may find two holes. If that is the case then the adapter plate on mine perhaps sends these two port holes to the rear control.
   / Adding rear hydraulics to L2250 #45
When you take that cover off it well be clear as mud. You can see what I'm talking about. I guess we can send as much as 10mb now. I know you said you had a parts manual but I sending the one I have, You can blow the picture up as big as you want. Go to Aux control valve #1 (option) or pg 127 in the pdf file.
  • L2250dt.pdf
   / Adding rear hydraulics to L2250 #46
Very clear. Thanks Leejohn.
It looks like if I were to remove the round cover with the two bolts on mine, the "connector" as I see it in the parts manual would bolt on in place of my round cover.
Part 030 99063-93300 CONNECTOR. Is this the part you said is $300? Guess I better fire up the Bridgeport.
   / Adding rear hydraulics to L2250 #48
Excellent. I was going to offer to fire up my mill and make one but you have that covered. :)
Not really... I inherited a bridgeport, but have not had a chance to learn how to use it. My background is as an auto tech, not a machinist.
   / Adding rear hydraulics to L2250 #50
Yes thats it. I was wrong about the olong oring, it has 2 orings the oil must pass into that cover and back out. Go to page 114 and you can see the 2 orings under that cover. Also if you hook in there you well not be able to use the remote valve and the 3pt at the same time. That part I think would be the same even if you pick up your hyds from the hyd block.
Year: 2014 Make: Chevrolet Model: Silverado Vehicle Type: Pickup Truck Mileage: Plate: Body Type: 4 (A55852)
Year: 2014 Make...
SKIDDED FRAC TANK (A55745)
SKIDDED FRAC TANK...
2022 Polaris Ranger Utility Cart (A53421)
2022 Polaris...
2012 Chevrolet Traverse LTZ SUV (A53424)
2012 Chevrolet...
(2) GAS HEATERS (A54757)
(2) GAS HEATERS...
2018 Ford F-150 Crew Cab Pickup Truck (A53422)
2018 Ford F-150...
