Adding rear hydraulics to L2250
   / Adding rear hydraulics to L2250
I'll have to pull up the parts manual again, but I thought it showed 2 orings, one for each port. I'll check and post back.
   / Adding rear hydraulics to L2250 #62
Yes thats it. I was wrong about the olong oring, it has 2 orings the oil must pass into that cover and back out. Go to page 114 and you can see the 2 orings under that cover. Also if you hook in there you well not be able to use the remote valve and the 3pt at the same time. That part I think would be the same even if you pick up your hyds from the hyd block.
That is what I said in this post
195082 (A57192)
195082 (A57192)
40' CONTAINER (A57192)
2011 INTERNATIONAL WORKSTAR 7400 SBA 6X4 DUMP TRK (A52706)
2011 INTERNATIONAL...
2024 JOHN DEERE 35P LOT NUMBER 107 (A53084)
2024 JOHN DEERE...
NEW HOLLAND 706 30 INCH 3PT DIRT SCOOP (A55315)
NEW HOLLAND 706 30...
JCB 3CX (A53317)
JCB 3CX (A53317)
