Adding rear hydraulics to L2250
   / Adding rear hydraulics to L2250
I'm trying to wrap my head around this. It's tapping into a pressure port on top of the 3 point, going thru an open center valve on the fender and returning back to the same port on the 3 pt? Or am I missing something? Here's what mine has at the same place.
Just trying to figure out how to tap into this?
   / Adding rear hydraulics to L2250 #44
Based upon what LeeJohn said a while back about an oblong O ring under the cover, I believe under the plate you may find two holes. If that is the case then the adapter plate on mine perhaps sends these two port holes to the rear control.
   / Adding rear hydraulics to L2250 #45
When you take that cover off it well be clear as mud. You can see what I'm talking about. I guess we can send as much as 10mb now. I know you said you had a parts manual but I sending the one I have, You can blow the picture up as big as you want. Go to Aux control valve #1 (option) or pg 127 in the pdf file.
  • L2250dt.pdf
   / Adding rear hydraulics to L2250 #46
Very clear. Thanks Leejohn.
It looks like if I were to remove the round cover with the two bolts on mine, the "connector" as I see it in the parts manual would bolt on in place of my round cover.
Part 030 99063-93300 CONNECTOR. Is this the part you said is $300? Guess I better fire up the Bridgeport.
   / Adding rear hydraulics to L2250 #48
Excellent. I was going to offer to fire up my mill and make one but you have that covered. :)
Not really... I inherited a bridgeport, but have not had a chance to learn how to use it. My background is as an auto tech, not a machinist.
   / Adding rear hydraulics to L2250 #50
Yes thats it. I was wrong about the olong oring, it has 2 orings the oil must pass into that cover and back out. Go to page 114 and you can see the 2 orings under that cover. Also if you hook in there you well not be able to use the remote valve and the 3pt at the same time. That part I think would be the same even if you pick up your hyds from the hyd block.
TURFMAST MHW2460 SWEEP-ALL PULL TYPE LAWN SWEEPER (A57192)
TURFMAST MHW2460...
2008 KZ Sportsman Police Bunk 5th Wheel Tri-Axle Travel Trailer (A51694)
2008 KZ Sportsman...
2013 Ford F-150 Ext. Cab Pickup Truck (A53422)
2013 Ford F-150...
UNUSED FUTURE 3' X 10" GALVALUME METAL SHEETS (A57193)
UNUSED FUTURE 3' X...
Caterpillar D6K LGP (A53317)
Caterpillar D6K...
2006 KAWASAKI MULE 3010 DSL UTV (A57192)
2006 KAWASAKI MULE...
