Adding rear hydraulics to L2250
   / Adding rear hydraulics to L2250 #31
I looked up the part and I don't know if it was a miss print or not, but if it wasn't you well not buy one. It said it was $300.00 and you know where they could put that. Just get one made, it's just a flat plate with 2 holes in it. Good and flat on one side and faced off for the o rings. A guy could use a back facing tool to do that. There is no way I would pay that much for a flat peace of steel with 2 tapped holes in it.
   / Adding rear hydraulics to L2250 #32
So how does the hydraulic fluid flow through it if it is a flat plate? I might well be able to machine a piece of 3/4" thick material with mounting bolt holes and then tap the plate over the hydraulic holes to accept a 3/8" pipe thread and groove for an O ring.
   / Adding rear hydraulics to L2250 #33
Your tractor is open center hyds and it goes into a OC valve and out the tank port of the valve. All you got to find out is what one on the tractor is pressure. With cover off just turn it over and you well see real quick, just don't start it if you can. Oil flows all the time the tractor is running.
   / Adding rear hydraulics to L2250 #34
What does your manual say about what line are what?
   / Adding rear hydraulics to L2250 #35
On the fender mounted valve there is a label "input". I will follow the line to the connection point on the tractor.
   / Adding rear hydraulics to L2250 #36
I miss understood part of your ?, right now the plate has a slot in it from one hole to the other with 1 oblong oring. That lets the oil flow all the time in the loop.
   / Adding rear hydraulics to L2250 #37
I miss understood part of your ?, right now the plate has a slot in it from one hole to the other with 1 oblong O ring. That lets the oil flow all the time in the loop.
My tractor has the actual factory adapter plate for the rear control. The plate with the oblong cover is not on mine. I could possibly manufacture a block that does the same thing as the factory take off cover. But I could be chasing a rabbit here in this conversation... That would not be new for me. :)
Are both press and return from your fender mounted valve going to the plate under the seat?
   / Adding rear hydraulics to L2250 #39
Yes you do not use a PB fitting, that's the way kubota's kit shows it.
forgive my foolish questions, what's a PB fitting?
(3) 6' X 4' EXPANDED METAL (A57192)
(3) 6' X 4'...
RITENHOUSE 400 GALLON ORCHARD BLOWER (A57192)
RITENHOUSE 400...
JMR Attachments Quick Attach Dirt Scoop (A56469)
JMR Attachments...
(APPROX 15) 2" X 6" X 20'- 3/8" THICK METAL TUBING (A54757)
(APPROX 15) 2" X...
2018 Jeep Grand Cherokee SUV (A55853)
2018 Jeep Grand...
UNUSED PABREAK GCC56-2 PRONG HAY SPEAR (A57193)
UNUSED PABREAK...
