Adding Power Beyond, 3-spool hydraulic valve, and T-n-T to a JD 2520
   / Adding Power Beyond, 3-spool hydraulic valve, and T-n-T to a JD 2520 #91
I think I'll go with this on my 2720 (which does have power beyond) after Christmas. I might have to purchase a few parts at a time though.:thumbsup::thumbsup:
   / Adding Power Beyond, 3-spool hydraulic valve, and T-n-T to a JD 2520 #92
Hello
Jim were right he make a good job (perfect with good picture) I have the manuel book for John deere 2320 and for the Banjo it 17N.m or 12 lbs-ft
M8x50 cap it 23-30N.m or 17-22 lbs-ft
Jim show inch pound but it look the same
Banjo bolt 150 inch pounds (8 mm hex wrench).
M8x50 cap screw holding DSCV on, 17-22 foot pounds
Thank Jim Good job you shoud be a good teatcher. Ha! Ha!
Sughikim: Welcome to Tractor By Net! And thanks for checking the torque specs for us.
   / Adding Power Beyond, 3-spool hydraulic valve, and T-n-T to a JD 2520 #94
I did not notice any check valves, does it raise and lower fast or do you think it would be an improvement with them ???
   / Adding Power Beyond, 3-spool hydraulic valve, and T-n-T to a JD 2520 #95
The check valves that you are talking about do not slow the control of the cylinders. They lock the cylinder in place and were first developed for safety purposes. The use of them on top and tilt cylinders compensates for leaky control valves. If you want to better control a hydraulic cylinder, you need to slow the flow down in some manner either by feathering the control valve or by reducing the flow with a flow restrictor.
   / Adding Power Beyond, 3-spool hydraulic valve, and T-n-T to a JD 2520 #96
I'm finally getting back to this project!
Phew! Man can the regular distractions of life get you off tract.
This is the valve I'm using. Surplus Center - 3 SPOOL 8 GPM PRINCE MB31BBB5C1 DA VALVE
It's an open center, so I don't think I need to add the block off or "high pressure carry over" plug and just use the standard "out" or return to tank line.
Here's a pic of my valve. The bracket is fabbed, but not finished and painted. Have most of the fittings and hose to plumb it all up.
The positions pretty good. It's not in the way of anything including the rock shaft lever or your elbow, but allows easy access to the levers without doing contortions to manipulate them. First two levers are for the TNT and the third one will have quick disconnects for an aux cylinder of some kind.
   / Adding Power Beyond, 3-spool hydraulic valve, and T-n-T to a JD 2520 #97
'SQUATCH' -- Looks great, nice and compact!
   / Adding Power Beyond, 3-spool hydraulic valve, and T-n-T to a JD 2520 #99
I agree, but I don't think there's a fitting on this model to return the flow to the tank. I haven't noticed anyone using more than one hose on the return side of the valves. Or I should say I haven't seen anyone using more than 2 hoses (ie input/output.
I know on this tractor the fluid has to flow throw the pb or any aux hydro valves and then through the scv for the FEL. I think it flows through the rockshaft valve first though. I'm going to plumb it using the open center port and see how it is (that's what's recommended). It shouldn't harm anything since the pressure won't dead head.
I am curious as I've heard some people on this thread state they've heard a noise after installing a spool valve or that their rock shaft stopped working.
   / Adding Power Beyond, 3-spool hydraulic valve, and T-n-T to a JD 2520 #100
Thanks Jim!
Your posts are a great inspiration for us who start these little projects on our little Deeres.
How you doing btw? I thought a while back you said you had Chemo.
KUBOTA SSV65 OPEN STATION CAB (A52706)
KUBOTA SSV65 OPEN...
Ford N Series Tractor (A59814)
Ford N Series...
2021 Ver-Mac PCMS-3812 Solar S/A Towable Trailer Message Board (A55973)
2021 Ver-Mac...
2019 MQ POWER WHISPERWATT DCA-25 GENERATOR (A58214)
2019 MQ POWER...
2020 MACK P164T (A58214)
2020 MACK P164T...
2008 KENWORTH T300 FLATBED FUEL TRANSPORT TRUCK (A58214)
2008 KENWORTH T300...
