Adding lights to ROPS
/ Adding lights to ROPS #21
<font color="blue"> Walmart has a 55 watt utility light with a magnetic base and a cord with a power plug (cigarette lighter type) for all of $15.00 or so. </font>
Normally $19,9?. bought one on clearance a couple of weeks ago for $10. It puts out more light than I though that it would.
/ Adding lights to ROPS #22
The magnets on mine must be weak. The 'Bota bounced them off....................chim
/ Adding lights to ROPS #23
I just mounted a pair under the top of my ROPS using a 1"x3" piece of oak (an idea I read here on TBN). I used 2" square U bolts, cut 2 blocks of the oak for spacers, and ran the wire up the back side of the folding ROPS. Be careful though, the hinge point on the ROPS provides one of the best wire cutters you can ask for /forums/images/graemlins/crazy.gif. I used longer bolts for the mounting brackets so I could place extra washers to allow the lights to be turned forward or backward, whether the ROPS is up or folded down. I also used the plug in type solderless connectors, so all I have to do is remove two U bolts and unplug, the whole light bar is off. The U bolts also served as a close point for the ground wires.
All I have left is to put a switch in the line. The dealer told me the auxiliary wire by the tail lights of my TC24D was part of the headlight circuit, which I took to mean it was through the switch. Nope - it's hot all the time the key is on. Having them independent is better anyway, I find the headlights to be a pain when the FEL is on.
Brad
/ Adding lights to ROPS #24
Removable lights...
How about using the detachable brackets made for the SMV signs ?
One bracket is permanently mounted to the tractor... the other to the light... the bracket on the light slides into the one on the tractor...
Can't find a picture of one... there only a couple $ each at tractor supply retailers...
Dave...
Thanks folks,
I know I'd get some good ideas. The magnets or the SMV brackets look like the way to go.
Bob
Murph,
Are "magnetic grounds" the same as what Harbor calls "pull magnets"? If so, what size pull do you recommend, 100, 150 or 200 lbs? I would think 100 lbs. would be more than adequate.
Bob
/ Adding lights to ROPS #27
Here are a couple of pictures of the lights I mounted on my <font color="orange"> Kubota </font> B2910. They are 20-watt fog lights that work very well. I used ½” aluminum plate to mount the lights.
The mounting is strong enough to pull low hanging branches out of trees without any damage to the lights. /forums/images/graemlins/tongue.gif
click here
click here
/ Adding lights to ROPS #28
I have to add my 2 cents. I have installed lights off a skidsteer. I added some bright flashing lights so I can be seen on the roads as I plow with this machine in the winter. See pics the lights were not completly installed in thes pictures I still had to wire them but they are done now.
/ Adding lights to ROPS #29
here is another pic
/ Adding lights to ROPS #30
yet another
/ Adding lights to ROPS #31
Bob,
The link should take you to what I used. They seem to fairly strong to me but they have to be flat on your roll bar to be good. My roll bar on the outer edges is rolled some and there the magnets don't hold to well. Yes trees and branches would knock them off. But I put them under my roll bar so they won't get hit so easy and I like the flexibility of being able to set them back wards really fast.
Grounding Magnets
Just take the bolts out and place your lights in place. Will need washers, enouh to get the bolt under flush for magnet to sit full.
murph
Murph,
Thanks. I had done a Harbor search for "magnetic ground", but this item did not come up. I'm going to order three right now.
Bob
/ Adding lights to ROPS #33
Hope it works out ok for you. They are kind of expensive so maybe you just want to try one and see if they hold strong enough for you. Harbor Freight does have a return policy I believe if you don't like them.
murph
2009 Chevrolet Silverado 1500 4x4 Ext. Cab Pickup Truck (A64556)
2009 Chevrolet...
42" Hydraulic Smooth Lip Swivel Bucket (A62679)
42" Hydraulic...
Landhonor 8'x10' Galvanized Apex Metal Shed (A62679)
Landhonor 8'x10'...
2012 WESTERNSTAR 4900FA (INOPERABLE) (A63569)
2012 WESTERNSTAR...
Kubota Industrial Turbo Diesel Engine - Tag Missing - Pump Takeout - Approx. 80-85 HP Class (A63689)
Kubota Industrial...
2014 FREIGHTLINER CASCADIA (A65643)
2014 FREIGHTLINER...
