adding external valves?
/ adding external valves? #11
Yes, that is correct about the flow..
You can parallel closed center valves but not open center valves.
If the selector switch is the source after the pump, then that hyd fluid will either go to the loader or the 3pt.
You can have fluid going from the selector valve to the remotes, and then the 3pt in series from the pump.
Pump ----selector valve----FEL----tank
Pump----selector valve----remote valve PB----3pt----tank.
i think that dinner and apple and blackberry crumble did me a world of good!!! :D
i just understood your last post! even just worked out that FEL means Fore End Loader :p
i have even figured out what PB does, it lets you add a valve in series whilst the oil then flows on to the 3 point as it is in this case :)
could i have this
Pump----selector valve----remote valve PB 1----remote valve PB 2-----3pt----tank.
rigtht so then, i need:
a double action, 2 bank spool valve with power beyond?
oh and i am in Britain so if i can get it in Britain that is even better! :D
Cheers Ed
/ adding external valves? #15
Yes, that is correct.
You could even do this.
cool i will look for a suitable valve then and then post here for you to check it!
we got a cab so routing is a bit more complex then that unless i mounted them just outside the rear window as i saw on a tractor exactly the same as ours at a recent ploughing match
Cheers Ed
/ adding external valves? #18
Yes, looks OK
/ adding external valves? #19
If your hyd system is open center, you can install valves in series with the flow.
Each valve should have PB.
cool, awesome thanks! so carry over port means PB?
i think it might almost be time to don my boiler suit and get down and dirty and find a suitable hydraulic line to cut :D
when we start the build i will post another thread with pics and descriptions all the way if it helps anyone else
Cheers Ed
2007 Sterling 360 COE 40/45 Box Truck (A59230)
2007 Sterling 360...
2019 DRAGON ESP 150BBL ALUMINUM (A58214)
2019 DRAGON ESP...
2015 Ford F-350 Versalift Bucket Truck (A59230)
2015 Ford F-350...
2011 Mercedes Benz GL AWD SUV (A59231)
2011 Mercedes Benz...
2004 CATERPILLAR 416D BACKHOE (A59823)
2004 CATERPILLAR...
2016 Ford F-150 Ext. Cab Pickup Truck (A59230)
2016 Ford F-150...
