Adding an extra outlet to a Terramite?
/ Adding an extra outlet to a Terramite? #1
QRTRHRS
Elite Member
The Bluegrass State
None at this time.
I just picked up a used T9 Terramite and am in the process of setting up the front loader with a skid loader type quick disconnect.
I also want to add an extra hydraulic inlet/outlet to use my grapple bucket.
I know enough to be dangerous about hydraulics. And, I don't know much about the machine yet either. Is there a simple solution that anyone can suggest?
/ Adding an extra outlet to a Terramite? #2
I don't know what a T9 is, I have owned a T5B for over 20 years. Without hesitation I would recommend calling Terrimite. Those guys with help with anything. I would also suggest you ask for a manual and parts list for your machine. They will also set you up as a customer so if you order something they have your info for shipping. 800-428-3772 They may also have a kit set up for your machine.
Sorry if I got off your question. Just thought I would give credit where due. I have even ordered universal parts like pins from them because they were much cheaper.
The T9 is the largest of the three models Terramite makes.
I will take your advise and call the company. They do have a 4-1 bucket availabel on the T9 so it is doable. Just have to ask if it is a simple retrofit for my 2001 year machine.
J_J, the selector valve sounds simple enough. I don't need anything too elaborate since this is just for use around my small farm.
/ Adding an extra outlet to a Terramite? #5
Here is the selector valve that I mentioned earlier.
https://www.surpluscenter.com/item.asp?item=9-7852&catname=hydraulic
https://www.surpluscenter.com/Instruct/I9-7852.pdf
This valve will let you curl the bucket with no voltage applied, or use the grapple by applying a voltage to the solenoid valve.
If you have continuous pressure above 2500 psi, then yu can use this valve.
https://www.surpluscenter.com/item.asp?item=9-7738-A&catname=hydraulic
https://www.surpluscenter.com/Instruct/I9-7738-A.pdf
