Adding an extra outlet to a Terramite?
   / Adding an extra outlet to a Terramite? #1
QRTRHRS
Elite Member
Liberty, Kentucky
None at this time.
I just picked up a used T9 Terramite and am in the process of setting up the front loader with a skid loader type quick disconnect.
I also want to add an extra hydraulic inlet/outlet to use my grapple bucket.
I know enough to be dangerous about hydraulics. And, I don't know much about the machine yet either. Is there a simple solution that anyone can suggest?
   / Adding an extra outlet to a Terramite? #2
I don't know what a T9 is, I have owned a T5B for over 20 years. Without hesitation I would recommend calling Terrimite. Those guys with help with anything. I would also suggest you ask for a manual and parts list for your machine. They will also set you up as a customer so if you order something they have your info for shipping. 800-428-3772 They may also have a kit set up for your machine.
Sorry if I got off your question. Just thought I would give credit where due. I have even ordered universal parts like pins from them because they were much cheaper.
The T9 is the largest of the three models Terramite makes.
I will take your advise and call the company. They do have a 4-1 bucket availabel on the T9 so it is doable. Just have to ask if it is a simple retrofit for my 2001 year machine.
J_J, the selector valve sounds simple enough. I don't need anything too elaborate since this is just for use around my small farm.
   / Adding an extra outlet to a Terramite? #5
Here is the selector valve that I mentioned earlier.
https://www.surpluscenter.com/item.asp?item=9-7852&catname=hydraulic
https://www.surpluscenter.com/Instruct/I9-7852.pdf
This valve will let you curl the bucket with no voltage applied, or use the grapple by applying a voltage to the solenoid valve.
If you have continuous pressure above 2500 psi, then yu can use this valve.
https://www.surpluscenter.com/item.asp?item=9-7738-A&catname=hydraulic
https://www.surpluscenter.com/Instruct/I9-7738-A.pdf
2023 Case IH 4412F 12 Row 30 In. Row Spacing Folding Corn Head (A50657)
2023 Case IH 4412F...
2012 Ford F-150 Pickup Truck (A50323)
2012 Ford F-150...
Bobcat Skid Steer Forks (A50322)
Bobcat Skid Steer...
2016 FREIGHTLINER CASCADIA DAY CAB (A51222)
2016 FREIGHTLINER...
2015 TRANSMASTER LOWBOY TRAILER (A51222)
2015 TRANSMASTER...
2014 Ford Explorer AWD SUV (A50324)
2014 Ford Explorer...
