add on bucket grapple
/ add on bucket grapple #21
Just got the ATI Grapple - see photo - it's great for moving RR ties, has already saved my back. Has anyone taken theirs off before? Either remove 8 bolts & take the whole thing (would be a monster to remount I think) or should I pull the 3 bushings where the jaws mount and the 1 on the cylinder?
/ add on bucket grapple #22
Buckee nice looking grapple. I would really like to see some shots of the backside where the cylinder is attached to the bucket. What did that set you back in dinero?
/ add on bucket grapple #23
Does anyone have the email address of the grapple maker.I'd like to get in touch with him to ask a few questions. Ted
/ add on bucket grapple #24
Looks like something I may be interested in....looking forward to your next week-end's workout! Seems the arms remove fairly easily??
/ add on bucket grapple #25
...Seems the arms remove fairly easily??
<font color="blue"> </font>
Yes the grapple is easy to take off by disconnecting the hoses and pulling the two pins for the grapple arms and the back pin for the hyd cylinder and its off. No tools required.
/ add on bucket grapple #26
Does anyone have the email address of the grapple maker.I'd like to get in touch with him.
You can contact the guy who makes the grapple sold on eBay by going to his eBay listing eBay Grapple and clicking on the link that says "ask seller a question". This is how I have contacted him.
The ATI grapple is sold through dealers you can email sales@preseeder.com to ask for dealers in your area. The ATI web site is here Contact ATI
John
/ add on bucket grapple #27
I received info on ATI's grapple. Since I am planning on using this for assisting in moving rocks with my JD4310 430 loader, I noticed that ATI's lit only talked about moving light materials (leaves, brush).
Does anyone have experience using a grapple to actually pick up and help hold rocks on their bucket?
Kent
/ add on bucket grapple #28
I have the ATI grapple and it works fine, however I have found that it is possible to pull something out from under it. In my setup there is about 15' of hose from the valve to the grapple. My guess is that there is enough expansion in the hose to let the grapple give some. This could be a problem with any grapple with a lot of hose feeding it.
I am thinking that a double piloted check valve like is used on hydraulic top links might be the solution to this problem. Any thoughts?
/ add on bucket grapple #29
A friend of mine and I were also discussing adding a double piloted check valve to his grapple cylinder as it seems he has a very similar situation. My bet is it would dramatically help the grapple stay in the closed position without having to hold pressure to the cylinder manually to keep it closed.
/ add on bucket grapple #30
Here's a closer shot of the ATI GK-4866 grapple on my NH TC33DA. Haven't had a chance yet to really stress it, but there's enough squeeze to easily lift & move a very waterlogged RR tie (one I couldn't even break free from the ground manually) in a straight up lift. I purposely kept the bucket pointed straight down as I moved it about 500 yds just to see if it would slip out - no movement at all. No manual pressure on the hydraulics was necessary. I do think it would benefit from some serrations in the jaws - as they come they're just a straight edge, will have to think on how best to do that.
One of my concerns was mounting & dismounting. I talked to ATI & they said no problem just driving out the 3 main pins & the one on the cylinder - they are all made with grease fittings & a locking crossbolt. Then I can pull just the jaws & the cylinder off & leave the crossbeam on, without having to undo the 8 bolts on the ends of the bucket. Otherwise remounting the whole monster would be a monstrous chore for 1 person I think. I don't think it needs to come off for most dirt & snow work anyway.
PineRidge you asked about cost - I don't really have a breakout because this was a throw-in in the deal I made for the tractor. I'd be curious what others have paid stand-alone. ATI's website is http://www.preseeder.com/attachments/
. They are very responsive to questions.
/ add on bucket grapple #31
We're starting to think out loud here and we really like the looks of the ATI grapple. We are fixing to do some holiday shopping at Surplus Center to pick up on a 12 volt selector valve to power up the grapple with the use of the joystick on our New Holland. Thanks for all the info, we're getting ready for a new project. /forums/images/graemlins/grin.gif
/ add on bucket grapple #32
</font><font color="blue" class="small">( I too believe it moves too fast & needs a flow restrictor in the hydraulic line. )</font>
I would also like to slow down my Virnig grapple.
With a double acting hydraulic cylinder such as on this grapple, is it necessary to put a flow restrictor in each of the hydraulic hoses? Or, is restricting just one of the hoses sufficient?
Can a simple pinhole restrictor be used, or are the one way ball valve type needed?
Thanks,
Tom
/ add on bucket grapple #33
Tom you may indeed use only one orifice to slow the cylinder down for both directions of travel. Both our T&T cylinders only have one in each.
/ add on bucket grapple #35
I tried the link and got a message that said that the url was not valid. What category was it in?
Thanks
TX, This works for me. It slows the grapple down both ways.
Flow Control Valve
Attachment is a picture of it on the tractor.
Just dial in the flow you want then lock down the set screw.
Gerald
/ add on bucket grapple #38
PineRidge,
Could you elaborate on the selector valve and or provide a link for one? Since I'm pretty new to all this tractor stuff, I'm unfamiliar with the setup to actually operate the grapple cylinder. Thanks.
/ add on bucket grapple #39
This is the selector valve that we ordered. It will actually be delivered tomorrow. click here.
We have ordered from these folks in the past and they have always taken care of us. Good service is a plus!
(2) 10ft Nesting Boxes (A65579)
(2) 10ft Nesting...
CASE CX160D EXCAVATOR (A65053)
CASE CX160D...
1994 DAKOTA MANUFACTURING CO. / TRAIL-EZE LANDALL TRAILER (A65643)
1994 DAKOTA...
STIHL HT250 POLE SAW (A64276)
STIHL HT250 POLE...
(4) Wheels and Tires for 4-Wheeler (A65579)
(4) Wheels and...
2009 IC Corporation School Bus, VIN # 4DRBUAAN39B694287 (A65563)
2009 IC...
