A quick check on something
/ A quick check on something #1
dustinfox
New Hampshire
Kioti CK35 HST
Hi folks... Spring is coming and the tractor is out of the barn! I just want to do a quick check on a delivery I have coming tomorrow....
Kioti CK35HST with 42" pallet forks from Titan skidsteer. My delivery weighs in at almost 1400 lbs. I've never actually weighed anything that I moved with this setup but will I be OK offloading this pallet from the delivery truck? I think the pallet forks themselves weigh around 300 lbs.
Thanks
/ A quick check on something #2
Front Loader Lift Capacity
The Kioti CK35HST can lift up to 1,764 lbs at a distance of 24" from the lift point. Do you have ballast in your rear tires?
Dennis
/ A quick check on something #3
Hang the heaviest implement you have off the three point, as much as you can to get to about 900 lbs or so
Thanks guys... I do have ballast in the tires and am hanging a 60 inch box blade off the back. I should be fine then!
/ A quick check on something #5
Do you have a rotary cutter? That would be better in most cases.
2006 John Deere 990 (A64126)
2006 John Deere...
1995 Freightliner FLD120 Tandem Dump (A62613)
1995 Freightliner...
International 154 Cub Lowboy, Gasoline, 60" Mower  (A62679)
International 154...
2012 DRAGON  130BBL VACUUM TRAILER (A65643)
2012 DRAGON...
John Deere (A64126)
John Deere (A64126)
INSPECTION (A65563)
INSPECTION (A65563)
