A quick check on something
/ A quick check on something #1
dustinfox
Gold Member
New Hampshire
Kioti CK35 HST
Hi folks... Spring is coming and the tractor is out of the barn! I just want to do a quick check on a delivery I have coming tomorrow....
Kioti CK35HST with 42" pallet forks from Titan skidsteer. My delivery weighs in at almost 1400 lbs. I've never actually weighed anything that I moved with this setup but will I be OK offloading this pallet from the delivery truck? I think the pallet forks themselves weigh around 300 lbs.
Thanks
/ A quick check on something #2
Front Loader Lift Capacity
The Kioti CK35HST can lift up to 1,764 lbs at a distance of 24" from the lift point. Do you have ballast in your rear tires?
Dennis
/ A quick check on something #3
Hang the heaviest implement you have off the three point, as much as you can to get to about 900 lbs or so
Thanks guys... I do have ballast in the tires and am hanging a 60 inch box blade off the back. I should be fine then!
/ A quick check on something #5
Do you have a rotary cutter? That would be better in most cases.
2006 STERLING AT9500 6X4 T/A 14FT DUMP TRUCK (A59914)
2006 STERLING...
2012 Ford F-150 Harley-Davidson Edition - 48k miles (A63689)
2012 Ford F-150...
2015 Chevrolet Express 2500 Cargo Van (A61573)
2015 Chevrolet...
2019 John Deere 460E 46 Ton Articulated Dump Truck (A64194)
2019 John Deere...
2022 EZ-GO ELITE...
(INOP) 2018 BOMAG BMP8500 TRENCH COMPACTOR (A60429)
(INOP) 2018 BOMAG...
