8n wont start
   / 8n wont start
ok i'll have to look at that tomorrow,
Thanks
   / 8n wont start
just to let all know i got the tractor running. the wire from the distributor to the coil was too heavy.
   / 8n wont start #13
to heavy? that makes no sense? it may have had a bad connection and when you changed it to a lighter wire it cleane dthe connection and worked.
you could have a peiec of 1/0 wire connecting them up.. or a solid ingot of copepr conencting them and it would work fine.
too heavy wasn't the issue.
too bad of a conenction was...
ps.. if that other ford was a 46.. it was a 2n.. or at least the egine was from a 2n...
   / 8n wont start
with the thicker wire i got 0.04 volts at the distributor, with the thinner wire I got 6.12 volts. I dont know what to say?
   / 8n wont start #15
Bad connection:thumbsup:
Soundguy is right. Wire size dont matter on that.
Anyway...glad you got it running. The 8n's are pretty easy and a good tractor to learn to work on:thumbsup:
How about posting some pics when you get a chance?
   / 8n wont start
ya your right doesnt matter about the wire, its runnng after two years sitting in a field. i'll see if i can get the pics to upload :) $T2eC16NHJHIE9nyseGi,BQ,JHzh,)!~~48_35.jpg$(KGrHqJ,!l!FBKg(MdtvBQ,JH(KINQ~~48_35.jpg
   / 8n wont start #17
Looks like a nice project.
Keep an eye on that front axle with that loader. The 8n didnt have a super strong front end, and has lots of things that can wear out.
Do you know if it has the sherman transmission? (It would have a dog-leg shaped lever on the transmission case just forward of the clutch pedal.)
   / 8n wont start #18
simple physics.
heaver conductive wire is LESS of a voltage drop than thinner wire of same conductor type.
unless you have magic powers to change those laws.. the reasonable answer was you had a bad conenction and the very ACT of changing out the wire, corrected the bad connection.
remember. sometimes a cigar is just a cigar....
not every part ever changed in history was a bad part. ;) that's why diagnostic techniques usually yeild cheaper repair bils in the long run due to not repalcing good parts.. :)
glad you got er up.
   / 8n wont start #20
wrong spot.. that's simple the clutch linkage :)
look up... :)
excavator trenching bucket- one bucket per lot (A56438)
excavator...
2019 Freightliner M2 106 AWD Altec DM47BTR Insulated Digger Derrick Truck (A60460)
2019 Freightliner...
2011 Chevrolet Silverado 2500 Pickup Truck, 127808 Miles, Utility Rack - GREAT WORK TRUCK (A56438)
2011 Chevrolet...
2007 CHEVROLET 3500 DUALLY 4X4 DIESEL TRUCK (A59575)
2007 CHEVROLET...
2018 JOHN DEERE 323E SKID STEER (A60429)
2018 JOHN DEERE...
1959 DODGE D510 DUALLY FLATBED TRUCK (A59823)
1959 DODGE D510...
