812 Front end loader leveling ?? on a 5252
/ 812 Front end loader leveling ?? on a 5252 #1
Dupa
S.E. MASS
CUB 5252E, JD LX176
Hello, new owner to a 5252 with a 812 front end loader. It is not level by about 1" to 1 1/2 ". I don't know how to level it using the hydrolics???
Any advice would be appreciated.
/ 812 Front end loader leveling ?? on a 5252 #2
check rear tire pressure.
Not the rear tire pressure or any pressure problem, I am checking the bolts for tightness next, No visually obvious bends in the frames. Moving on.. must adapt
/ 812 Front end loader leveling ?? on a 5252 #4
If its not the tires, might be a sprung loader frame. I think that's pretty much impossible to fix.
/ 812 Front end loader leveling ?? on a 5252 #5
Like mentioned,tire pressure FRONT and rear. If ok , sounds like the loader mounts are off some.measure from lower side of each mount to a flat surface. There is some "Play" in the holes of most loader mounts....as you move to the leading edge of the bucket......a little difference at the mounts becomes alot.
/ 812 Front end loader leveling ?? on a 5252 #6
what happens if tractor on level surface -loosen mount screws-apply down pressure on bucket-tighten mount screws!!!
