5030
Rest in Peace
- Joined
- Feb 21, 2003
- Messages
- 28,967
- Location
- SE Michigan in the middle of nowhere
- Tractor
- Kubota M9000 HDCC3 M9000 HDC
78\" snowblower modification?
I have had my Lucknow 78" rear mount blower for a few years now and the clearance between the fan and the circular housing in which it rotates has grown somewhat do to a lot of use and the abrasion of dirt and gravel that gets injested by the auger and fan during normal operation.
I wanted to pick everyone's brain out there as to whether I can dismount the fan this spring and affix rubber ends to each blade (made from 1/4" thick belting) to reduce the clearance and improve the efficiency of the blower. I am wondering whether the rubber ends would have any longevity, opinions needed.
In lieu of that, I could weld extensions on each blade to take up the clearance and then balance the fan assembly. I use this blower quite a bit in the winter to clear the road from the farm to the main road. I thought the rubber would be an easier replacement when the time came again. After all, when you buy a blower it should last a lifetime.
It (the blower) would really make my 5030 work. My new M9 just loafs along.
