78" snowblower modification?
/ 78" snowblower modification? #1
5030
Rest in Peace
SE Michigan in the middle of nowhere
Kubota M9000 HDCC3 M9000 HDC
78\" snowblower modification?
I have had my Lucknow 78" rear mount blower for a few years now and the clearance between the fan and the circular housing in which it rotates has grown somewhat do to a lot of use and the abrasion of dirt and gravel that gets injested by the auger and fan during normal operation.
I wanted to pick everyone's brain out there as to whether I can dismount the fan this spring and affix rubber ends to each blade (made from 1/4" thick belting) to reduce the clearance and improve the efficiency of the blower. I am wondering whether the rubber ends would have any longevity, opinions needed.
In lieu of that, I could weld extensions on each blade to take up the clearance and then balance the fan assembly. I use this blower quite a bit in the winter to clear the road from the farm to the main road. I thought the rubber would be an easier replacement when the time came again. After all, when you buy a blower it should last a lifetime.
It (the blower) would really make my 5030 work. My new M9 just loafs along.
/ 78" snowblower modification? #2
Re: 78\" snowblower modification?
I believe that belting should work fine and as you mentioned, it would be easy and inexpensive to replace. UMHW strips in about 1/4" thick might be something else to consider.
/ 78" snowblower modification? #3
Haven't seen it done,
but what about a polyethelyne liner in the
fan housing?
replaceable, and would reduce any drag, and
might improve the flow of the snow thru it..
/forums/images/graemlins/confused.gif
/ 78" snowblower modification? #4
I think the belting strips should work fine but strips of UHMW PE would have less drag and may be a better choice. I think I'd give that a try first.
Good Luck,
Kevin
2020 CATERPILLAR 262D3 SKID STEER (A62129)
2020 CATERPILLAR...
2018 International WorkStar 7400 T/A Lely 4,500 Gallon Septic Wet Vacuum Truck (A61568)
2018 International...
1997 Chevrolet Kodiak C6500 Aerial Crane (A62613)
1997 Chevrolet...
CAT 930M (A58214)
CAT 930M (A58214)
2025 Swict 84in. Skid Steer Bucket Attachment (A61567)
2025 Swict 84in...
TRI PAC EVOLUTION APU (A60736)
TRI PAC EVOLUTION...
