3-Point Hitch 7010 Info + 3pt quick connect usage
/ 7010 Info + 3pt quick connect usage #1
NetworkMD
Montana 5740C
I would like to know from the 7010 group do you like the built in 3 pt quick connect system??
Does it require the use of the connection balls that come with it, or will they connect directly on a standard Cat 2 pin?
I welcome any other comments on the 7010 Good or Bad
Thank you
/ 7010 Info + 3pt quick connect usage #2
Hi Network......
:rolleyes:
Three point Linkages can be used for category 2 type of implements or category 1 by using reducing bushes......
I don't think there is a need of a connection ball, it should connect directly with the standard spc.
Thanks how have you liked your 7010? the reason I asked is the demo I used had balls that needed to be placed on the implement pins.
/ 7010 Info + 3pt quick connect usage #4
Yes, you have to have the ball on the implement. Enjoy that new machine and good luck with it.
2019 BOBCAT E26 EXCAVATOR (A63276)
2019 BOBCAT E26...
ASSORTED STIHL POLE SAW PARTS (A62613)
ASSORTED STIHL...
New/Unused Landhonor Tree/Post Puller (A65583)
New/Unused...
2011 HEIL TRAILER (A65643)
2011 HEIL TRAILER...
(12) 4.5"x9' Steel Posts (A66408)
(12) 4.5"x9' Steel...
Conveyor Belt (A64194)
