3-Point Hitch 7010 Info + 3pt quick connect usage
/ 7010 Info + 3pt quick connect usage #1
NetworkMD
Montana 5740C
I would like to know from the 7010 group do you like the built in 3 pt quick connect system??
Does it require the use of the connection balls that come with it, or will they connect directly on a standard Cat 2 pin?
I welcome any other comments on the 7010 Good or Bad
Thank you
/ 7010 Info + 3pt quick connect usage #2
Hi Network......
:rolleyes:
Three point Linkages can be used for category 2 type of implements or category 1 by using reducing bushes......
I don't think there is a need of a connection ball, it should connect directly with the standard spc.
Thanks how have you liked your 7010? the reason I asked is the demo I used had balls that needed to be placed on the implement pins.
/ 7010 Info + 3pt quick connect usage #4
Yes, you have to have the ball on the implement. Enjoy that new machine and good luck with it.
