6v and not charging
/ 6v and not charging #1
Bansil
State Of Franklin
1967 Ford 5000 w/FEL(sold), 1950 Farmall Super A for the wife to drive around (needs fixed) 2024 Kubota B2601 FEL & BH
1950 Farmall Super A, it has an 8v battery and across posts at high idle 7.3v or so
This is after some time on a 6v battery charger so obviously it is not charging, searching the web I found many diagrams showing a 3 wire regulator and the body being grounded(corrosion seems to be a big issue between block and housing)
I have not pulled it off and just yanked the cover for a picture, any troubleshooting for these 4 wire ones?
I have not traced wires yet, I have 1/2 of day tomorrow off and will look at her between projects trying to reference 3 wire diagrams and also using a meter to see if 4th wire is a redundant ground
I have not "energized" the field yet or checked contacts , I will try tomorrow
Thanks
/ 6v and not charging #2
I've worked on many farmall wiring systems and never saw a 8 volt battery on any of them, that said 7.5 volts on a 6 volt system isn't bad. If you google farmall a wiring diagrams and click on images you'll find about every diagram in existence, I would check the generator for a third brush and see if the headlight switch has two positions for charging rate. My 2 cents.
Thank you, the only reason for the 8v bat. is to hide that the 6v gen. is not working correctly
I plan to replace the "small 12v sized" battery cables and get it working correctly
Thank you for the pdf that will help!
okay I found this:
About 12" of burnt wire, it shorted at the wire tie beside shifter
So I replaced it with some 8ga I had
Then put battery back in (took it out to trace and verify panel wiring)
I polarized generator and started tractor, no charge...said a few choice words and noticed it was charging at ~10 amps, tried lights , nice and bright and then noticed it was -15 amps! with lights off?
So I glanced into the generator opening (no cover) and good see random sparks (not from armature/brush area?)
so I disconnected battery and removed generator opened it up and....
notice the "A" brush with no tension? spring is broken
chaffed, burnt and broken wire
NOPE 2 chaffed wires and notice the springs and brush holders, bent crooked and...the "A" brush is broken
So now need to decide what next step is? Buy a 6v generator, voltage regulator (contacts are very pitted and you can "smell" burnt electrical)
also need correct sized battery cables (cracked, old and 12v size) also I need 2 6v bulbs for lights
I may do a 12v swap...we will see
what are ideas, this tractor will not be restored any time soon, if ever, wife likes it like it is
/ 6v and not charging #6
Do you have a good starter/generator repair in your area..?? Much cheaper to rebuild that, then buy. A good regulator will run you $100. I got mine through my local gen. shop. A good name brand 6V battery, and at least 1/0 cables, and it will start like it should. You'd think it was 12V.
All of my smaller IH's are still 6V system, and work like they should.
Bush Hog 3715 (A64126)
2014 Chevrolet Camaro (A62613)
2014 Chevrolet...
2017 John Deere 6110M (A64126)
2017 John Deere...
2022 Keystone RV Coleman Camper Trailer, VIN # 4YDTCMN20NH931920 (A65563)
2022 Keystone RV...
New/Unused Receiver Hitch Ripper (A65583)
New/Unused...
2019 VOLVO A45G OFF ROAD DUMP TRUCK (A62129)
2019 VOLVO A45G...
