6v and not charging
/ 6v and not charging #1
Bansil
State Of Franklin
1967 Ford 5000 w/FEL(sold), 1950 Farmall Super A for the wife to drive around (needs fixed) 2024 Kubota B2601 FEL & BH
1950 Farmall Super A, it has an 8v battery and across posts at high idle 7.3v or so
This is after some time on a 6v battery charger so obviously it is not charging, searching the web I found many diagrams showing a 3 wire regulator and the body being grounded(corrosion seems to be a big issue between block and housing)
I have not pulled it off and just yanked the cover for a picture, any troubleshooting for these 4 wire ones?
I have not traced wires yet, I have 1/2 of day tomorrow off and will look at her between projects trying to reference 3 wire diagrams and also using a meter to see if 4th wire is a redundant ground
I have not "energized" the field yet or checked contacts , I will try tomorrow
Thanks
/ 6v and not charging #2
I've worked on many farmall wiring systems and never saw a 8 volt battery on any of them, that said 7.5 volts on a 6 volt system isn't bad. If you google farmall a wiring diagrams and click on images you'll find about every diagram in existence, I would check the generator for a third brush and see if the headlight switch has two positions for charging rate. My 2 cents.
Thank you, the only reason for the 8v bat. is to hide that the 6v gen. is not working correctly
I plan to replace the "small 12v sized" battery cables and get it working correctly
Thank you for the pdf that will help!
okay I found this:
About 12" of burnt wire, it shorted at the wire tie beside shifter
So I replaced it with some 8ga I had
Then put battery back in (took it out to trace and verify panel wiring)
I polarized generator and started tractor, no charge...said a few choice words and noticed it was charging at ~10 amps, tried lights , nice and bright and then noticed it was -15 amps! with lights off?
So I glanced into the generator opening (no cover) and good see random sparks (not from armature/brush area?)
so I disconnected battery and removed generator opened it up and....
notice the "A" brush with no tension? spring is broken
chaffed, burnt and broken wire
NOPE 2 chaffed wires and notice the springs and brush holders, bent crooked and...the "A" brush is broken
So now need to decide what next step is? Buy a 6v generator, voltage regulator (contacts are very pitted and you can "smell" burnt electrical)
also need correct sized battery cables (cracked, old and 12v size) also I need 2 6v bulbs for lights
I may do a 12v swap...we will see
what are ideas, this tractor will not be restored any time soon, if ever, wife likes it like it is
/ 6v and not charging #6
Do you have a good starter/generator repair in your area..?? Much cheaper to rebuild that, then buy. A good regulator will run you $100. I got mine through my local gen. shop. A good name brand 6V battery, and at least 1/0 cables, and it will start like it should. You'd think it was 12V.
All of my smaller IH's are still 6V system, and work like they should.
