65HP Utility Tractor
/ 65HP Utility Tractor #61
I bought my 6530 as shown, new in '07. It replaced a JD 4230DC (100 hp row crop 2wd) had and is currently running it's implements. Apparently I am happy with it as I bought it's little brother in 2016 without shopping any other badge. I do my own work and do not need any dealer connectivity so having one next door is not necessary for me. A parts list and UPS is all I need. Had I needed such and a field servicing contract and somebody to do all my maintenance then I would have bought a JD which I advised my new neighbors to do and they did and they are happy.
Here's better pics of the 4WD 5065. I wasn't sure about the wide ride on this on but it comes with a good price. Has the joystick and mid valves. Would this setup be a good fit for what I'm looking to do? I plan on adding a front bracket and moving the weights over from the 2350.
Also would you recommend keeping the width? Or switching to a narrower stance?
In the ad, it mentions 2 mid SCVs + joystick and rear SCVs. One thing I need to get info on is it doesn't mention the warranty. Would there be anything that would void warranty with the tires being wide?
Thanks for the info on the filled tires, I may look into that later if needed.
/ 65HP Utility Tractor #66
No. The tires wouldn't void the warranty. I have mine set out pretty wide too. Makes for a nice ride if you do much side slope mowing.
Those have a 2yr/2000 hrs warranty.
Brett
Thanks to everyone's input throughout this process, I really appreciate it. Everyone made this much easier and hopefully I can work out the price to make it work. Never knew how much thought it takes to decide on the right tractor. Of course if money wasn't an option it would be much easier.
/ 65HP Utility Tractor #69
Very nice tractor buckeye21. Personally I like the wide stance on my 4610SU. I have some hills and slopes and the added stability with the loaded rears is well worth it. I was pretty adamant about adding the ROPS to my older tractor. I was fortunate to find a factory ROPS for it at a decent price. The only downside is if you need to trailer your tractor you may need a deck over. Right now I am at 84" and I bet you are close to that also. I've always liked that model of tractor from Deere.
/ 65HP Utility Tractor #70
I deff wouldn't mind a wider stance for stability on hills.
2020 TROXELL CONCEPT 130 BBL STEEL VACUUM TRAILER (A63569)
2020 TROXELL...
2014 MAC FLAMELESS HEATER TRAILER (A67714)
2014 MAC FLAMELESS...
2023 CATERPILLAR 299D3 SKID STEER (A65056)
2023 CATERPILLAR...
2022 JCB 509-42F TELESCOPIC FORKLIFT (A65053)
2022 JCB 509-42F...
2000 STERLING LT8500 SERIES WATER TRUCK (INOPERABLE) (A67714)
2000 STERLING...
Wheel Loader Root Rake (A68134)
Wheel Loader Root...
