654 temp gauge
/ 654 temp gauge
Still have not resolved this. Can't find a good location for the aftermarket without hacking up the hoses.
There is a small hose off the water pump, but I will have to pull the hose and identify the threads to install a tee. That would be the cleanest, but nobody seems to know what the threads are.
/ 654 temp gauge #12
Where is the idiot light sensor? Can you remove it and install a sender for a gauge.. In most applications you can. NOt sure what your thermostat housing looks like, but I have seen over height housings with a port for mechanical gauge on the bottom. And, you could probably fab a spacer with a threaded hole for a sensor, to sandwich under the stock housing.
/ 654 temp gauge
I'll look into that. Thanks for the suggestion.
2006 TRAIL KING ADVANTAGE PLUS RGN/DETACH TRAILER (A58375)
2006 TRAIL KING...
1761 (A58375)
1761 (A58375)
2023 Kubota M4-061 Deluxe MFWD Utility Tractor with LA1154 Front Loader (A55315)
2023 Kubota M4-061...
2012 INTERNATIONAL PROSTAR+ (A60736)
2012 INTERNATIONAL...
GENERAC MAGNUM PORTABLE LIGHT TOWER (A59823)
GENERAC MAGNUM...
Bigfoot Plastic Baler (A57148)
Bigfoot Plastic...
