6410 jd
/ 6410 jd #1
Greg Mckenzie
john deere 6410
hydralics leak off on 3rd arm, and also the wet lines keep spitting out. what can be done
/ 6410 jd #2
I would recommend that you tell us what kind of tractor you have and describe the problem in detail.
/ 6410 jd #3
check the couplers for dirt or rust. get new plug in's .replace o rings in the coupler. explain 3rd arm. i think you mean a hydraulic top link. could be bad plug in's.
/ 6410 jd #4
Are you saying that the 3pt leaks down, or something is leaking on the 3pt lift arms?
Is the 3rd arm your TNT cyl?
/ 6410 jd #5
jj i think leak off means that it will not hold position. that could be caused by bad coupler,cylinder o rings or valve.
/ 6410 jd #6
I agree with the leaking seals, but also, the 3pt lever may not be in neutral.
2023 Cat 259D3 Skid Steer (A64194)
2023 Cat 259D3...
(15) Polyethylene Road Bed Protection Pads (A60462)
(15) Polyethylene...
2015 CATERPILLAR M313D MOBILE EXCAVATOR (A64279)
2015 CATERPILLAR...
2003 Ford Ranger Pickup Truck (A61573)
2003 Ford Ranger...
2007 International 4300 Bucket Truck 55' (A62613)
2007 International...
Excavator trenching bucket- one bucket per lot (A63689)
Excavator...
