6410 jd
/ 6410 jd #1
Greg Mckenzie
john deere 6410
hydralics leak off on 3rd arm, and also the wet lines keep spitting out. what can be done
/ 6410 jd #2
I would recommend that you tell us what kind of tractor you have and describe the problem in detail.
/ 6410 jd #3
check the couplers for dirt or rust. get new plug in's .replace o rings in the coupler. explain 3rd arm. i think you mean a hydraulic top link. could be bad plug in's.
/ 6410 jd #4
Are you saying that the 3pt leaks down, or something is leaking on the 3pt lift arms?
Is the 3rd arm your TNT cyl?
/ 6410 jd #5
jj i think leak off means that it will not hold position. that could be caused by bad coupler,cylinder o rings or valve.
/ 6410 jd #6
I agree with the leaking seals, but also, the 3pt lever may not be in neutral.
2016 GENERAC MMG025IF4-01 MOBILE POWER (A59912)
2016 GENERAC...
Case 1020 25ft Draper Head (A63118)
Case 1020 25ft...
2004 Isuzu NPR 14ft. Box Truck (A61573)
2004 Isuzu NPR...
2021 Harley-Davidson FLHP Road King Motorcycle (A61574)
2021...
2018 CATERPILLAR TL1055D TELESCOPIC FORKLIFT (A62129)
2018 CATERPILLAR...
INTERNATIONAL 4900 GRAIN TRUCK (A63291)
INTERNATIONAL 4900...
