6410 jd
/ 6410 jd #1
Greg Mckenzie
john deere 6410
hydralics leak off on 3rd arm, and also the wet lines keep spitting out. what can be done
/ 6410 jd #2
I would recommend that you tell us what kind of tractor you have and describe the problem in detail.
/ 6410 jd #3
check the couplers for dirt or rust. get new plug in's .replace o rings in the coupler. explain 3rd arm. i think you mean a hydraulic top link. could be bad plug in's.
/ 6410 jd #4
Are you saying that the 3pt leaks down, or something is leaking on the 3pt lift arms?
Is the 3rd arm your TNT cyl?
/ 6410 jd #5
jj i think leak off means that it will not hold position. that could be caused by bad coupler,cylinder o rings or valve.
/ 6410 jd #6
I agree with the leaking seals, but also, the 3pt lever may not be in neutral.
2025 Greatbear Rachet Tie Down & Flatpack Tool Box (A61567)
2025 Greatbear...
2018 Ford F-350 (A55973)
2018 Ford F-350...
2012 Volkswagen CC Sedan (A61569)
2012 Volkswagen CC...
2016 Isuzu NRR 18ft. Flatbed Truck (A61568)
2016 Isuzu NRR...
2016 Yanmar Vio45 (A62177)
2016 Yanmar Vio45...
2023 Caterpillar 259D3 Compact Track Loader Skid Steer (A61567)
2023 Caterpillar...
