6410 jd
/ 6410 jd #1
Greg Mckenzie
john deere 6410
hydralics leak off on 3rd arm, and also the wet lines keep spitting out. what can be done
/ 6410 jd #2
I would recommend that you tell us what kind of tractor you have and describe the problem in detail.
/ 6410 jd #3
check the couplers for dirt or rust. get new plug in's .replace o rings in the coupler. explain 3rd arm. i think you mean a hydraulic top link. could be bad plug in's.
/ 6410 jd #4
Are you saying that the 3pt leaks down, or something is leaking on the 3pt lift arms?
Is the 3rd arm your TNT cyl?
/ 6410 jd #5
jj i think leak off means that it will not hold position. that could be caused by bad coupler,cylinder o rings or valve.
/ 6410 jd #6
I agree with the leaking seals, but also, the 3pt lever may not be in neutral.
