6110 cab questions??
/ 6110 cab questions?? #1
cks68
hernando,MS
mahindra
I am looking really hard at a 6110 Cab with FEL.I was just wondering how well the a/c will do in the MS summer heat?I have read where some cab owners have had a lil trouble ect.I will probably get the glass tinted to help.I have been looking for a couple years and I have about made my mind up.I will be using the tractor to maintain 135 acres.Any other 6110 owners out there?How well do you like it?
/ 6110 cab questions?? #2
Just bought one two months ago. So far I am pleased (70 hours). There is a recall or service bulletin on ac. It leaks out if the ceiling, the warranty repair solved the problem and actually improved performance. I am in Texas and spent 6 hours this past weekend mowing... 90 degrees sunny and very humid at least 80%. Ac kept up fine until condenser got dirty. I will probably tiny the windows.
This is not a heavy ag tractor, it is very capable and well built though. So far I would recommend for most general farm uses.
/ 6110 cab questions?? #3
I have been using the AC in mine for a little bit now......It hasnt been super hot yet here in AR, but it is coming. Lately i have the AC on about half/blend and with the fan on low and i have been plenty comfortable. I made the mistake of only running two vents with the fan running on a higher setting and ended up getting condensation leaking in the headliner. Be sure to open all your vents and let the fan blow.
I'm over the 50 hr mark now and will be posting an in depth review of the 6110....from why i bought it to how it performs.
Thanks for the info. I will make sure the dealer has checked this warranty repair before I have them load her up!!
/ 6110 cab questions?? #5
The original set up is four vents across the wind shield. Upgrade will add two "arms" that relocates outer vents back towards the driver. Also, it will have a newer style blower assy. and drain pan. It is a package deal so if it looks like this you are good to go,if not it will rain inside...a LOT.
Hope you get a good deal. Enjoy.
It definately doesnt look like this.....Thanks for the pics! I will be checking on this for sure!!
I have been waiting on a timber sale,which just happened a few days ago.I am going to dealer again this Saturday and hopefully make the deal.
/ 6110 cab questions?? #9
This is the warrenty repair from Mahindra cause mine didn't get this all they did was wrap the excisting pipe with insulation and it didn't help.
Finally!!!After changing dealers I took delivery on a new 6110 shuttle cab with FEL and a HD cutter!!
/ 6110 cab questions?? #13
cks68 what dealer did you buy your new 6010 from and how do you like it? i live in sardis ms and was thinking about getting a new 6010 too. Thank you for any help Sammie
