5425 Tractor
/ 5425 Tractor #1
cantelonj
London , Ontario
5425 John Deere
I have a 5425 tractor/542 loader and I went out to cut hay yesterday and was shifting threw the gears and hit a small pothole (barely noticeable) and the tractor seemed to pop out of gear , it slowed down and stopped but when I went from forward to reverse the tractor won't move....really weird , checked the switch on the seat and ohm's out fine ....stumpted any ideas???
/ 5425 Tractor #5
Do you have left hand reverser? If so, then I would suspect an electrical problem. Are any warning lights on? Check all your fuses and relays. A bump could have knocked one loose possibly.
/ 5425 Tractor #6
Seat switch ?
Power Reverser Fuse.
/ 5425 Tractor
Seat switch is good , all fuses test fine....has the electronic clutch...think either the ecu is bad or clutch is out
/ 5425 Tractor #8
I'm assuming it has PowerReverser ?
Make sure all 4 elc connections are securely connected on left side of trans under your left foot sitting in seat.
My 5093E did this too.
/ 5425 Tractor #9
how about the range and the gear levers are they both in gear?
/ 5425 Tractor
Had john Deere out and pressure tested the clutch , clutch is bad , have the tractor almost split , parts here sat....
/ 5425 Tractor
Yes , should have explained further , it has a froward solenoid and a reverse solenoid actuated by a rehostat on the clutch pedal instead of the traditional cable setup....more stuff to go wrong....JD says when you lose both for/rev usually means the clutch is out. Mine all the springs were in the bottom case. Took about 9 hrs to repair including removing/installing loader.
/ 5425 Tractor #17
PR still working good ?
How many hours on this JD ?
