5425 Tractor
/ 5425 Tractor #1
cantelonj
London , Ontario
5425 John Deere
I have a 5425 tractor/542 loader and I went out to cut hay yesterday and was shifting threw the gears and hit a small pothole (barely noticeable) and the tractor seemed to pop out of gear , it slowed down and stopped but when I went from forward to reverse the tractor won't move....really weird , checked the switch on the seat and ohm's out fine ....stumpted any ideas???
/ 5425 Tractor #5
Do you have left hand reverser? If so, then I would suspect an electrical problem. Are any warning lights on? Check all your fuses and relays. A bump could have knocked one loose possibly.
/ 5425 Tractor #6
Seat switch ?
Power Reverser Fuse.
/ 5425 Tractor
Seat switch is good , all fuses test fine....has the electronic clutch...think either the ecu is bad or clutch is out
/ 5425 Tractor #8
I'm assuming it has PowerReverser ?
Make sure all 4 elc connections are securely connected on left side of trans under your left foot sitting in seat.
My 5093E did this too.
/ 5425 Tractor #9
how about the range and the gear levers are they both in gear?
/ 5425 Tractor
Had john Deere out and pressure tested the clutch , clutch is bad , have the tractor almost split , parts here sat....
/ 5425 Tractor
Yes , should have explained further , it has a froward solenoid and a reverse solenoid actuated by a rehostat on the clutch pedal instead of the traditional cable setup....more stuff to go wrong....JD says when you lose both for/rev usually means the clutch is out. Mine all the springs were in the bottom case. Took about 9 hrs to repair including removing/installing loader.
/ 5425 Tractor #17
PR still working good ?
How many hours on this JD ?
iDrive TDS-2010H...
WINCO PTO GENERATOR ON SINGLE AXLE TRAILER (A63291)
WINCO PTO...
case 370 glass door never installed (A61307)
case 370 glass...
JMR Tree Spade Mini Skid Steer Attachment (A61572)
JMR Tree Spade...
2015 Hagie STS 12 Sprayer (A63111)
2015 Hagie STS 12...
2025 PJ CC162 T/A 16FT EQUIPMENT TRAILER (A59912)
2025 PJ CC162 T/A...
