4x4 Question
/ 4x4 Question #141
HomeBrew2 said:
Fair enough ... I think. You proposed my "absolute" statement was flawed but, you can only presume that your stance can be proved with a mic. I accept that it is possible to prove it that way. I see no contest ... unless you are willing to prove your point by performing an experiment, such as the one I performed that was proposed by the fellow that I was ACTUALLY responding to, and QUOTED.
I believe the context of this thread, and my reply, probably not withstanding my "baiting" punctuation, are in harmony. If you'd like to dwell on my single sensational comment, feel free to do so. I have plenty of time. The key issue , to me, is, is there any REAL reason to NOT to be in 4WD when on a non-paved/HIGH-traction surface. In my view, no one has provided ant evidence to that end, eventhough I performed the challenge to which I replied (and quoted).
Cheers!
Heres some real reasons:
It uses more fuel.
It uses more tires.
It causes more turning radius and ground disturbance.
It causes more stress, heat, and wear on the entire system.
It requires more HP constantly.
/ 4x4 Question #142
Hmm.. I see we are at the point of hammering out minutia... that probably doesn't serve much at this point.... probably time to move on.
Soundguy
/ 4x4 Question #143
Soundguy said:
All I can say is that from an engineering standpoint, the more stress a part is under. the more it will wear compaired to a similar part not under that load.
Soundguy
That is undeniably correct. But from there we probably have too many other variables to come up with any one single rule in regard to use of the front drive train.
It is my assumption, based on what I know about my specific make and model of tractor, that using the front drive constantly, in the proper conditions as outlined in the manual, that it should last as long as any other component on the tractor. And given that my manual only hints at one single condition under which using the front drive might cause problems (to the tires, it says), it would seem that I can keep mine in 4wd at all times unless I'm driving on pavement and expect not premature wear. (Soundguy, I know you didn't suugest premature wear, but others did and still are. And I agree that if I never used it it would never wear.)
Now, other people have tractors whose manauls say take it out of 4wd any time it is not specifically needed. I'd say those folks really need to do exactly what their manual says, there has to be a reason for it saying so.
Finally, I think it is also safe to say that for my specific make and model of tractor that you can add wear to other components when you get yourself into situations in which you should have been in 4wd.
I guess that summarizes my position on the matter, but if I had to boil it down to one statement I'd say "do what your manual says do."
How many more posts do we need before this thread sets some sort of record?
/ 4x4 Question #144
All a person has to do to know that there is stress, binding, increased pressure or what ever is to look at the number of posts over the years that have ask how to get the 4wd lever to disengage easier. They are almost always told to lift the front with the loader, backup, straighten the front wheels or check the air pressure in the tires. If there weren’t any stress, binding, pressure or whatever they wouldn’t need to do any of these maneuvers.
/ 4x4 Question #145
put me down for flipping the lever back and forth all the time.
on for loader and ground engageing work (ie my back blade)
off for tight turns on the grass because it tears up the grass. ive watched the front inside tire with it both in and out of 4x4. when in there is aprecable scrubbing involved because the wheel cant spin fast enough when in 4wd.
/ 4x4 Question #146
A picture is worth a thousand words.
Here is the exact reason why it is hard on a drivetrain, truck or tractor, to turn in 4x4 on hard packed surfaces. http://home.comcast.net/~eliot_www/4wd.gif
Its not hard to imagine that the whole drive system, front and rear axles and transaxle, are effected. The front and rear axles are being turned the same speed but traveling different distances. This is why it either slips (scuffs) or binds when turning in 4X4. The more traction, such as on concrete, heavily loaded, the more binding and stress is put on the drivetrain.
/ 4x4 Question #147
Dang good point Jerry!!! Wish I had thought of that example. It's the same with some Jeep people. I've saw them destroy their transfer case shifter linkage yanking on the lever to get it to disengage right after completing a short turn. What do you say to people like that???
/ 4x4 Question #148
Well, all that assumes locked front and rear diffs. Open diffs, HST and center diffs in fancier 4wd (SUVs, some trucks) takes a lot of those stresses out of the picture.
Regardless, I don't think _anyone_ is arguing that it is a good idea to run a 4wd tractor with the front driveline engaged on pavement or any surface in which the wheels cannot slip a little.
/ 4x4 Question #149
Sorry but the binding I described has nothing to do with locked diffs. Although locked diffs will make it worse, they are not the root cause. And we've totally beat the cause into the ground on this thread. Even have a picture posted now to describe the problem. If it's not understood by now, it's not going to be understood. :)
Edit: N80, if you believe that a locked diff could contribute to binding the driveline, why is it that you can't seem to believe that an engaged MFWD can cause the same binding?? A locked diff is simply a MFWD engaged, turned sideways on the machine. :)
/ 4x4 Question #150
Ya cant argue with em. - - As I see it the main problem is the owners manuals that say "Stop the tractor when engaging or disengaging 4WD". This is safer than engaging while turning, or while going fast or slipping which should never be done, but applying this rule across the board eliminates the telling experience one gets when disengaging in varied circumstances.
Going straight gives some resistance because the fronts are set up slightly overdriven to "stretch" the tractor. This gives good small correction steering response. Backing up "compresses" the tractor to the same effect. A neutral stress point, giving easy disengage, is reached quickly after changing direction as stretch yields to compression.
A slight turn of just the right radius will bring front/rear into a complete neutral stress match and give easy disengagement.
A hard pull, or particularly a hard push or a hard turn, will make disengagement quite difficult.
A mental picture of what is happening, and a little experimentation are good tools to find easy, and any easy to disengage implys easy safe engagement as well.
Larry
/ 4x4 Question #151
For what it's worth I was tilling a couple food plots yesterday and was in and out of 4wd probably 100-200 times. Never any binding getting in and out of it. Here's my procedure:
Enter the food plot, pop it in 4wd shift into 1st or second.
Drop the tiller at the end.
Till to the end of the row.
Once the front tires clear the end, pop it back in 2wd.
Lift the tiller at the end, turn a bit away from where I want to end up.
Shift into third, stomp on the cutting brake and turn around the back tire, teardrop shaped.
Line up for the next row, repeat step 1.
Sometimes I was going straight when I engaged/disengaged, sometimes I was turning. Often as I was lining up on the next row I'd have to engage it when turned to pull the front end into line. Yet again, use it when you need it, read your manual to find specifically whether or not your specific system has caveats and warnings that apply to you.
/ 4x4 Question #152
Open axle diffs wont stop the binding because the front tires still travel a different path then the back ones. If you have a center diff in the transfer case (All wheel drive or full time 4WD) there wont be any binding.
I think people are arguing that its a good idea. They are choosing to do it over disengaging the 4WD. They must believe its a better idea than operating in 2WD or this thread wouldve disappeared long ago.
/ 4x4 Question #153
My 4 wheel drive just went out and I didn't even get that snowball out of Texas!!! Must have used it too much when it was new.
/ 4x4 Question #154
There you are!!! I've been looking for you to help you with that project and here ya go and tear up your tractor before I get there!!! :) :) :)
/ 4x4 Question #155
Well, the 'picture' offered as proof (of what I'm still not sure) is pretty much a stick figure showing that the outside front travels farther than the inside front. I'm not sure that has ever been a point of dispute.
But the thing is, Ovrszd, you're acting like you are privy to some special rule that applies to all CUT's and yet, when I've explained how my owner's manual reads and how my tractor works, you've made excuses and made up mythical systems that it doesn't have in order to shoe-horn your idea into a shoe that it does not fit.
The front diff on my tractor, most I'm assuming, is open. Only one wheel gets traction so binding is minimal except in tight turns. As I've told you, there is no binding that I can feel, not in tight turns or otherwise. There is no chatter. There is no feedback in the steering wheel. NONE. There is NO change in turning radius. So is there _some_ binding? Certainly. Of course. Is this likely to be a problem over the lifetime of my tractor? Of course not. It was made with 4wd. It was made to use 4wd. It was made to last as long as the rest of the tractor.
I'm not sure where you come off assuming that those who take your advice are wise and that those who do not are somehow dangerously hardheaded.
I've read my owner's manual cover to cover. It includes such wisdom as pointing out that diesel fuel is flammable, and yet it includes NONE of the wisdom that you can't believe that some of us won't accept. And this isn't some former Soviet block Yugo-trac, its a late model Kubota.
So if your advice is so rock solid, why doesn't my manual say anything? Why doesn't it warn that the front driveline is weak and must be handled with care (remember when you implied that the front drive line was a weak link?)? Why doesn't it say to take it out of 4wd when not needed? Why doesn't it say to take it out of 4wd even when on pavement? And no, it doesn't have some special (mythical) anti-binding system. Its about as basic a machine as anyone makes.
All I've said is to follow your owners manual. If that sounds hard headed, tell me why.
/ 4x4 Question #156
ovrszd, thanks for the offer in helping me, but it has grown to astronomical proportions and even with your help we wouldn't be able to even budge it! It has totally amazed me at how something so small could have grown so big.
I'm just going to limp on back home in 2 wheel drive. Thanks again.
/ 4x4 Question #157
N80, I bow to your superior knowledge and experience. I never offer advice in these posts, only opinion. I have never stated mine is the only one to have. I base my opinions on the basic laws of physics. Sometimes I'm right on the mark. Sometimes I'm way off. Apparently this time I'm way off. Again I bow to your superior knowledge, intelligence and experience. Everyone can now feel totally comfortable in driving their tractors in 4wd whenver they like. When I get home I've gotta work on all my 4x4 equipment and figure out why mine binds up and yours don't. Thank you N80 for resolving this lengthy discussion. Now excuse me because I have a snowball to go push, in 2wd. :)
/ 4x4 Question #158
Well I guess the "stick figure" picture with no written explanation wasn't enough. Try this http://www.4x4abc.com/4WD101/def_turn.html
I dont dispute what your manual says, I do dispute the wisdom of what it says (or doesnt say). Problem with that? Do you now see and understand that the front end needs to turn a different RPM than the rear when turning or you will get some amount of scrubbing?
/ 4x4 Question #159
New Holland has fixed the issue by offering an optional Sensitrak
from NH site.
"Sensitrak™ allows you to use FWD full time when the job demands it. Or, you can switch to the automatic mode and let Sensitrak do the thinking for you. Sensitrak knows when to engage or disengage FWD by comparing the speed of the front wheels with the speed of the rear wheels. If you're working in poor conditions and the rear wheels slip, Sensitrak smoothly engages FWD to pull you through. This happens whether you're traveling in a straight line, making a slight steering correction, or turning fully. When you're working on firm ground, Sensitrak knows FWD is not needed, and will disengage, allowing the front wheels to roll freely, protecting your turf and saving wear and tear on your front tires."
As far as Im aware, Kubota doesnt offer this on their compact tractors. I could be wrong though. Maybe you got the first one.
/ 4x4 Question #160
After rereading my posts, I apologize for my smarta$$ comments, Im trying to cut back but its not easy. The real point of the post was to educate, not berate.
2007 50FT T/A 3 CAR HAULER TRAILER (A59914)
2007 50FT T/A 3...
2013 GMC Sierra 2500 HD 4x4 Ext. Cab Pickup Truck (A64556)
2013 GMC Sierra...
Kubota V3600-T-E2 Turbo Diesel Engine - 3.6L - 84 HP - Tier 2 - Irrigation Takeout (A63689)
Kubota V3600-T-E2...
250 Gallon John Deere Sprayer (A65579)
250 Gallon John...
KILLBROS GRAVITY FLOW WAGON (A64277)
KILLBROS GRAVITY...
Forklift Boom (A62679)
