4x4 Question
/ 4x4 Question #121
Soundguy said:
Yep.. I actually had to go back and re-read the thread to pick all that back up.
I'm not sure at this point that we can add anything.. .. the info, as was posted above, and sumamrized here has been re-hased abot 3 times now...
Soundguy
LOL yea this was a very sucsefull thread. I think we coverd every every posible senearo and then some. I think you could make a clear choice based on the information discused hear.
/ 4x4 Question #122
broomjob said:
On my property, I have a "Engage 4wd" sign at the end of my driveway. That way I am reminded to shift into 4wd when I return from the pavement.
To me 4wd is like a seatbelt, if you dont have it on all the time, it will be off when you need it most.
I like that. But why not have a dashboard light that says "MFWD off"? I
know a previous poster mentioned something like this. My Toyota is good
enough to have a "4WD on" light, and it is of great value. My bad
experience many years ago helps me remember very well these days, but
we are all getting older......
/ 4x4 Question #123
My sister had a mustang once the had a light come on the dash and told her when to shift. It was cool because that was the car she bought with no idea how to drive it.
/ 4x4 Question #124
I have been thinking that I could use the underground wire that surrounds my property with an invisible dog fence system. I could wear the shock collar around my neck when I am on the tractor. That way when I return from the 2wd pavement and approach the wire, ZZZZZZZZZZZZZZZZap!!!!!!!!!. That should remind me to shift back to 4wd. It would also remind me to zip my pants.
/ 4x4 Question #125
I have these collars for my Dobermans and they have a remote control and a dial that you can control the amount of power to the shock. You could just give the remote to your wife and she could train you properly. You might even stop peeing on the floor around the toilet
/ 4x4 Question #126
What setting would she use if she caught me peeing in the sink.
/ 4x4 Question #127
I have always had 4wd vehicles and usually do not engage until I actually need it, but It only took me one time going down a slick steep hill in 2wd on my TN to understand when I need to engage 4wd on my tractor.
While I typically operate in 2WD, I will now engage the mfwd before I think I need it, especially when working on the slopes. Even dry looking ground can be deceptive.
Do what you want, but I would rather wear out my 4wd than wear out my luck.
/ 4x4 Question #128
Somehow I missed this whole thread till now. Intersting info, heard it all before. Yes, my tractor (770 hrs) is in 4WD all the time unless on pavement. Yes, my ranch truck is in 4WD all the time unless on pavement and has been used as such for a decade or so. Agree with a combination of Redrocker and 3RRL ... If I live long enough for them to break, I'll fix 'em :cool:
/ 4x4 Question #129
Perhaps attached it inside your pants and you WIL act on it.. :) OK we've gone down hill but we're still having fun.
/ 4x4 Question #130
Mentioned this before but we old timers get to repeat ourselves...
Tight manuvering in 4X4 tends to tear up the surface many times more viciously than in 4X2. I have a well packed nearly like black top drive made of shale. Driving on it in all sorts of weather does not even begin to rough up the surface. If I do a sharp turn in 4X4 on it then it roughs it up pretty badly. I have areas "paved" with crushed limestone and it gets messed up really quickly if I try a little "square dancing" on it with tractor in 4X4.
Other than driving on pavement or trying to avoid tearing up the surface with manuvers I just stay in 4X4 most of the time. Of course I have brush hogged and sprayed and such on more level ground in 4X2 but that isn't the majority of what I do with this tractor.
I have seen several folks who hitch their brush hog to a tractor and leave it there until one or the other wears out, years later. They are not typically so keen on 4X4 as I am. Maybe more of their land is more level than mine.
One of my friends just bought an old 8N with a brush hog on it. He intends to use it as a mowing machine and may never detach the brush hog. This leaves his actual tractor available for varioius dutines without fussing with the brush hog.
We recently were doing some work together, he with his 100HP Industrial rig (4X2) and me with 39 PTO HP Kubota 4X4. I suppose you can guess the relative merits of our tractors in our multiple cattle guard installing adventure or I wouldn't be mentioning it.
Pat
/ 4x4 Question #131
In West (by God) Virginia I always have mine in 4WD due to the hills, mud and slippery conditions.......same for my pickup that has chains on all four and never comes out of lo-lo. Some places you just HAVE to use the 4WD.
My tractor and pickup never leave the 75 acre property. It' so bad that I can't park more than 7 vehicles in an all weather flat spot on the entire property. I envy y'all with flat terrain, but wouldn't give up the mountains for a place where everyone wants to be (too many people), everyone wants to know what your doing (they're hurting my property value), everyone wants to say what you should do (don't even think about doing it without a permit), and everyone wants to charge you an arm and a leg for services (taxes).
I can well understand how some can get away with using 2 WD most of the time and I'll agree that if you can.......then go right ahead as it should be less wear and tear. But for some of us......we really don't have much choice.
/ 4x4 Question #132
Who was it that said "if'n you were to grad ahold of W. VA and stretch it flat then it would become one of the largest states in the Union?
I know whatcha mean about those mountains, they're all around my valley. :D :D
Volfandt
/ 4x4 Question #133
ovrszd said:
For those of you that insist on running in 4x4 all the time, here's my challenge to you. Engage your 4x4 on your lawn, turn your front tires halfway to the steering lock, drive forward until you have completed half a circle. Stop, lower your loader bucket (if so equipped), pick the front tires up until they are off the ground. Notice how they will "spin" as soon as you start lifting weight off them??? That's the torque and twist of axles, driveshafts, gears, etc., that is stored in your front drive system from turning in 4x4. Does that not bother you?? Then continue to drive around in 4x4.
Another easy example of this torque is to engage 4x4 on a gravel driveway, turn the front wheels to the lock either direction, drive forward and complete a full circle turn around. Notice how the front tires are scratching and clawing at the gravel??? That is happening every time you turn around in 4x4 regardless of what ground type you are on.
First, the two portions of your "challenge" post, that I have quoted, are mutually exclusive. The first portion, correctly, proposes a buildup of energy by, to put it simply, the rear axle fighting the front axle. The second quoted portion, correctly, proposes THAT energy being released periodicly thru the manuver. ... seems like there's some kindof an equlibrium law in physics and I think that is a good example of it.
So, for no good reason that I can think of, I just went out and took your challenge:
OF COURSE I did not perform your experiment on paving nor rock slabs. My soil is bullet-proof clay to clay-loam ... scarifiers bounce off it ... it's a desert here. I turned a circle at half lock, then I turned a few circles at half lock, then I turned a half circle at full lock, the several at full lock ... each time using the bucket to check for axle/drive train "unwinding" ... DID NOT HAPPEN! Did the same experiment with my '80 Dodge Ramcharger with 33x12.5 tires (jacking up after each trial) .... NO UNWINDING !
I'm wondering if your tractor and little jeep have fatigued axles and/or drivetrains. That is a possibility, by simple metalurgy.
So my question is ... if you're not on pavement (concrete, asphalt, soil cement, etc) nor raw rock, where's the APPRECIABLE wear that would lead to a repair that is out of the "norm" :confused: I propose that there is no evidence that such "increased" "measurable" wear exists when a tractor is driven in 4WD all the time on dirt, weather needed or not.
Cheers!
Cheers!
/ 4x4 Question #134
HomeBrew2, I have a BX1500 - similar to your tractor. There is definitely stress in the drivetrain in 4WD. Since these tractors are so close coupled actual windup is minimal. The tires just slip slightly and constantly. The speed match front to back is near perfect when going straight and becomes perfect in a gradual turn. After this point, turning sharper causes the front wheels to be pushed because the path they travel grows ever longer than the rears. This slipping increases your turning radius. Try comparing turning ability in and out of 4WD. If youre just turning on level ground the 2WD drive mode will give a tighter turn because the front tires are allowed to rotate freely and conform their speed to the path they are taking. Turning up a steep hill may be aided by 4WD tho, but not as much as if they were turning fast enuf for the long path they take.
Larry
/ 4x4 Question #135
HomeBrew2 said:
I propose that there is no evidence that such "increased" "measurable" wear exists when a tractor is driven in 4WD all the time on dirt, weather needed or not.Cheers!
I would think basic physics would show that there is extra measurable wear on a part under a load, vs a part not under a load.
Take 2 identical bearings, ( same lube, same gearbox ) run one freewheeled under no load.. run the other under varrying load conditions.. run them both the same # of thousand hours.. etc.. I can't see anything scientifically that would say the part under load would wear -LESS- than the part under no load... I just don't think you have any scientific basis to back that statement up.
It may take a piece of plastigauge or a micrometer , or gear surface/ bearing end play inspection to view this wear.. but I can't see anything that would say that the components under stress would not wear any more than the units not under the 'extra' stress.. etc.
I'm not saying 'undue' stress.. I'm not saying 'catastrophic failure'.. I'm saying the aprts run under extra stress will exhibit more wear.
Anyone ever notice that the driven front tires on a machine don't last as long as non driven ( non braked ) front tires ? ( tread.. not specifically casing life..)
Soundguy
/ 4x4 Question #136
Larry, when I sober up I'll re-read your post but, right now, I think we agree on all principles. Maybe that's what you were saying. Not sure.
Cheers!
/ 4x4 Question #137
Soundguy, Thanks for taking the bait. Usually my posts end the thread so I like to add an "impossible to justify" comment to keep it going. Of course you are right on all counts ... as long as we are using a mic ;)
Now on more serious terms, given your back ground, have you ever seen premature failure of a front-end that was engaged all the time, as compared to one that was shifted in and out as needed? ... that was my real point ... and I know you realize that, but I appreciate your reply :)
/ 4x4 Question #138
As was stated.. my post was not directed toward premature failure.. it was simply stating that extr awear accrues when using 4x4 full time vs shifting between the two.. nothing more.. nothing less.
Hard to chalk up a failure on any specific part to any specific cause.. unles you have an action that you can directly relate to a failure.. like.. ramming a pile with a loader bucket at full speed, then hearing a snap, and then seeing a bent bucket mount.. that's an example of a failure that is directly attributable to the previous action.
Bearing wear, normal or otherwise is harder to track. I have deffinately seen 4x4 components that were shelled out from driving on hard surfaces in short periods of time. But where do you point he blame without breaking it down for periodic measurement in comparison to a similar unit doing similar work.
Might have been a manufacturing defect.. like wrong bearing preload.. or any number of causes.
All I can say is that from an engineering standpoint, the more stress a part is under. the more it will wear compaired to a similar part not under that load.
Soundguy
/ 4x4 Question #139
Soundguy said:
As was stated..
Fair enough ... I think. You proposed my "absolute" statement was flawed but, you can only presume that your stance can be proved with a mic. I accept that it is possible to prove it that way. I see no contest ... unless you are willing to prove your point by performing an experiment, such as the one I performed that was proposed by the fellow that I was ACTUALLY responding to, and QUOTED.
I believe the context of this thread, and my reply, probably not withstanding my "baiting" punctuation, are in harmony. If you'd like to dwell on my single sensational comment, feel free to do so. I have plenty of time. The key issue , to me, is, is there any REAL reason to NOT to be in 4WD when on a non-paved/HIGH-traction surface. In my view, no one has provided ant evidence to that end, eventhough I performed the challenge to which I replied (and quoted).
Cheers!
/ 4x4 Question #140
Any real reason??.. I believe at least one good one has been posted. Sounds like 'torn up grass on a tight turn' seems to top the list.
That is, in context now, if you are on flat 'safe' land, .. not wet.. no hills.. no embankments or ditches... you could probably save some wear and tear on sod by disengaging 4x4.
that fit your test?
Soundguy
PS.. as for:
<unless you are willing to prove your point by performing an experiment>
Sure.. you go purchase 2 tractors, one locked in 4x4, and the other 2x4.. set them up to run on a test course for 2000 hours.
I already have the micrometer and plastigauge... and I'll pay for the front end oil anylisis that will likely show more metal content ( thus bearing and gear facing wear ) on the 4x4 unit. I'll also pay for a detailed surface inspection of the gear tooth facings, compaired with each other, and a third 'control' un-used gear.
The oil anylisis should show the metal content and we should be able to read that against a bearing wear table. We do this for our heavy equipment ALL the time instead of tearing half a million dollar machines down to just check the bearings... it's very telltale.
Side and end play, and gear backlash can be checked with a good set of feeler gauges. I can't help but expect the unit run in 4x4 for the 2000hr trial will show increased wear on bearing surfaces and/or gear tooth facings vs the unit not run in 2x4. etc..
Sound fair?
Soundguy
One other side note that is somewhat relevant.
Look at a diffy.. take 2 equal tractors. now put one different tire on one of the units rears.. run them around... would you expect to se more wear on
the diffy in the unit that had the unequal tires? I would.. and have seen it... that equates to extra workand stresses on that diffy vs a unit that was not recieving that extra work and stresses.
John Deere 5000-Series Tractor Grill Guard (A65640)
John Deere...
2023 ANDERSON IFX720 CONTINUOUS BALE WRAPPER (A64277)
2023 ANDERSON...
2024 Deere 320G (A64126)
2024 Deere 320G...
New/Unused Wolverine 84in Quick Attach Rock Bucket (A65583)
New/Unused...
2025 SDLANCH IRGC40 Two-Seat Electric Tricycle (A64194)
2025 SDLANCH...
2002 John Deere 4510 (A64126)
2002 John Deere...
