sandman2234
Super Member
- Joined
- Dec 4, 2005
- Messages
- 6,931
- Location
- Jacksonville, Florida
- Tractor
- JD2555 and a few Allis Chalmers and now one Kubota
With few exceptions, I think the original question has been answered the same.
Two wheel drive until you need it, and then only on soils that will allow safe spinning of the tires. On anything harder than packed clay, ALWAYS disconnect the front wheel drive, especially if you are loading a bucket or other device that loads the front end with weight.
There are certain exceptions to this rule, such as my lawn mower. It is 4 wheel drive continously, and the only way to change that is with a wrench to disengage one or both drives. It is hydraulic drive, one motor to each axle, so falls under a different class, dispite the fact that it is probably larger than some of your tractors...
The fact that a person operates his own particular vehicle in 4wd full time, is his own decision, and unless he changes tractors every few years, he will suffer for that decision. Hopefully I won't be the new owner of one of those used tractors.
David from jax
David from jax
