4x4 Question
/ 4x4 Question #21
I am in 4x4 24/7, (except on pavement) To me its all about safety, not wear and tear on the drive train. I would rather have rapair bills than rehabilitation bills. You flatlanders might get away with 2 wheel, but where I am (NH white mountains) being in 2 wheel means you are never more that a 45 degrees away from a very exciting downhill run.
/ 4x4 Question #22
I leave it in 4wd most of the time. The only time I take it out is when driving on pavement or when I don't want to dig the soil up as much when mowing. With Ag tires on the front it really cuts the grass up when turning in 4wd.
I don't buy the argument that using 4wd causes any sort of accelerated wear. I suspect that 4wd system is made to last as long as the rear drive system with constant use. But, I also don't believe running it all the time necessarily adds wear to the tractor. I do think driving in two wheel drive until you have to put it in 4wd to keep going puts additional wear on the whole tractor. When in 4wd you don't need as much engine power to get the same task done (if traction is required) as you would in 2wd. In other words, straining the tractor in any way just in order to accomplish a task in 2wd is probably more likely to add premature wear than using 4wd all the time. Using 4wd also keeps the front drive components well lubed.
In any case, its up to the individual but I disagree with the notion that using it all the time accelerates wear to the tractor. That shouldn't be a reason not to use it anyway.
/ 4x4 Question #23
Henro said:
We need to keep in mind that whether the tractor is locked in 4x4 mode, or not, the gears and shafts still turn all the time anyway. The only difference is that stress resulting from slight differences in gearing between the front and rear is eliminated. Such stress results from a small amount of overspeed designed into the system, where the front tires are made to turn slightly faster than the rears, by design, not chance.
When the 4x4 is not locked in.. there will be no load on those front end components.. i.e. .. no driveline runup from different front / rear ratio. That equates to slightly less wear on the front end. I'm not sure I have ever seen a front axle drive shaft or front diffy break while in 2wd mode!! I've sure seem em crack or wrung off in 4wd and when in a bind.
Henro said:
For me, living in the hills of western PA, there is a safety margin that is increased by keeping the tractor in 4x4. When not in 4x4 braking is by the rear wheels only. If I have something in my loader bucket, going down hill can reducing the amount of breaking available to the rear tires. 4X4 mode gives me better control overall.
My comment specifically addressed this as a broad 'exception'.. I.E. If you need it use it. Hills would be a prime situation to use it.. better control and breaking. If you are gonna argue the point.. you have to be fair... as this specific instance, was mentioned. Gotta keep it apples to apples here.
Henro said:
If tractors had hubs that could be locked/unlocked like a 4x4 truck does, I would buy into the idea that taking the tractor out of 4x4 mode saves wear (and some tear) on the front end components. But since they don't, I guess I don't either.:)
The logic of your post states that since the tractors don't have lock in 4x4 hubs, then there is no extra wear.
From a physiscs point I can't buy that. If the front end is freewheeling vs under load, then there will be more wear while under load. I'd be hard pressed to believe otherwise.
Soundguy
/ 4x4 Question #24
N80 said:
I don't buy the argument that using 4wd causes any sort of accelerated wear. .
So you are saying that a dead axle freewheeling is not going to wear any system components any faster than when being worked in 4wd. Keep in mind we are refering to bearing and bushing wear, gear facing wear, shafts and fasteners.
Since when in 4wd,t he front axle will be driven, all front end components will be under extra stress of 'leading' the tractor, and when turning, they will actually be fiting the rears, which can be seen when grass or dirt scuffs to allow the oversped front to stay ahead.
That can't be anything but accelerated wear. As i said before.. I never saw a front drive shaft break while in 2wd use...i.e. when not under any load. I've seen plenty of them snap when in 4wd.
I'm not purporting drastic wear like the front end is gonna fall off in 'x' years.. I'm talking about absolute wear.. that is.. if you took a visual inspection of the parts, checked them with a mic... I'd expect to see more wear and wear in marks in a front end section that has .. say.. 2000 hrs of constant 4wd use, vs a front end section that had low/no 4wd use.
Soundguy
/ 4x4 Question #25
Sorry, but your front end driveline is not designed to last as long as the rear driveline, that's just simple physics. The manufacturers do not have to build it to last as long because it's not intended to be used as much.
Secondly, it requires more engine power to do a task in 4x4 versus 2x4, again simple physics.
I'll offer one last test to explain the stress you are putting on your tractor when driving around in 4x4. Put your tractor in 4x4, go out in the lawn or in the driveway or wherever you like. Turn the wheels to half lock or full lock or whatever degree of turn you choose. Drive until you have completed half a circle. Stop the tractor. Now with the engine at an idle, begin to move again gently and slowly. Whether you are HST or gear/clutch equipped, you will notice a significant resistance to movement. You will have to push harder on the HST pedal or lug down the engine more than normal when engaging the clutch to get the tractor to move out of it's resting position. Why is that???
It's because again you have the drivetrain stressed and what us Jeepers call "bound up". In Jeeps I have saw this stress so strong that the "drive" ujoint on the driveshaft will begin movement as much as 1/8th of a turn before the driven ujoint moves, twisting the driveshaft.
You can call that whatever you want. "Properly lubricating your front end parts." "Taking less power to do the same task." "Being safe." Whatever feels good in your mind. I call it undue stress on your driveline. I call it premature failure of driveline parts if done long enough.
Like Soundguy said, it's not like the front end of your tractor is going to fall off tomorrow or that you are destined to buy new frontend parts next week. We are just saying, it's unnecessary wear, plain and simple.
And as Soundguy said, when you need 4x4, use it. When you don't need 4x4, don't use it. Real simple. And again, your tractor will thank you!!! :)
Lastly, I don't have an owners manual over here with me, but will someone get out their owners manual and tell us what it says about using the 4x4 feature, when to engage, when to disengage???
/ 4x4 Question #26
My point is that your argument on wear in a front drive system is kind of like saying that if you don't use a tool it will wear less than if you do use it. That's kind of obvious. I'm not saying that using it doesn't result in _any_ wear.
My point is that the front drive train in these tractors is designed to be used and I suspect it is designed to stand up to constant use for the life of the tractor. Taking it out of 4wd in order to 'save' the front drive system simply doesn't make any sense. It was made to be used. Using it at times when it is not 'needed' (low stress, good traction) is unlikely to add enough wear to it to have any impact on the useful life of the tractor. And it is _not_ analogous to the 4wd systems in most light trucks and SUVs. Most of these systems are made for occasional offroad use. I dare say this is hardly true of any decent tractor.
My other point, and I thought it was clear, was that if you are only engaging 4wd when you lose traction, then you are likely adding unnecessary wear to other parts of the tractor.
And citing that you've only seen front drive shafts break when in use is kind of self evident too. Very few tools break when they aren't used. Unless you see front drive shafts breaking during typical '2wd' type use, then there isn't much of a point there. If someone breaks a front drive shaft they are either abusing the tractor or they are using it in a situation that demands 4wd.
It really just comes down to defining when it is needed. That is up to the individual. My final, and main point is that constantly going in and out of 4wd for the sole reason of protecting the front drive system is probably pointless and the only likely _eventual_ outcome of such diligence would be pristine front drive line in an otherwise worn out tractor.
/ 4x4 Question #27
Ovrszd, what evidence do you have that the front drive lines are not designed to last as long as the rest of the tractor? Is this true for all tractors?
Also, with my L4400 there is absolutely zero binding, as you describe. And before you say anything, I'm quite familiar with 4wd systems and the phenomenon you are describing. In fact, I've never owned a vehicle that was not a 4wd. I've spent a lot of time driving offroad in everyhting from Willys Jeeps, IH Scouts, the old full sized Jeep Cherokees, The big AM General pick up, Chevys, Fords, Nissans, Toyotas. I've felt binding while turning at full lock in many of these (my current F150 being by far the worst of any of them) but I can assure you, if it is happening in my Kubota, I can't tell.
But I think it really all comes down to someone producing evidence that the 4wd systems in typical CUTs are not made to last as long as the rest of the tractor. If that is the issue then yes, we should all be carefully conserving our front drive lines. But I don't buy it for a second and won't until I see proof. When I do, I'll be the first to start worrying that my front drive line will go before the rest of the tractor and I'll do as you advise.
/ 4x4 Question #28
And I disagree with your simple phyiscs. If I'm reving and spinning to get up a slippery hill vs doing the same thing at idle speed while in 4wd, then I'm not stressing the engine as much. Certainly not more in any case.
/ 4x4 Question #29
Lots of opinions, folks vary. I don't own anything but hills and never take my tractor out of 4 wheel drive. But then, it is never on pavement either. I've gotten stuck enough times with the tractor in 4 wheel drive that it is not worth it to me. I prefer to keep it in 4 wheel drive to avoid as many problems as possible. Similarly, I almost always put my pickup in 4 wheel drive if I think it is going to be needed, which is everywhere on my property other than my drive. If I owned flatter ground, I probably wouldn't have payed the extra for a 4 wheel drive tractor.
Some argue that it is unnecessary wear on the tractor, and for them, they are correct. That using 4 wheel drive causes wear is not disputable, what is disputable is the the "unnecessary" part, and that of course varies with the individual. I'm using the tool I purchased exactly the way I want to use it.
Barry
/ 4x4 Question #30
I don't understand what all this bickering is about :confused:
If you "need" your tractor in 4WD all the time then leave it there. No one ever said any different.
/ 4x4 Question
Wow, lots of response, sounds like alot of friction between opinions. Sorry for that, Cant we all get along? Kidding. Thank you for all the info. I don't have any pavement, but I think I will start to switch between 2wd and 4wd a bit. Like I said, I have most hilled areas and lots of clay, but I think it would be good to switch it up a bit.
/ 4x4 Question #32
Its not bickering, its hard headed tractor people talking about tractors. ;-)
Seriously though, this is not exactly what has been said here. There is the idea that the front drive train is a weak link that is not made to last as long as the rest of the tractor components. If this is true, then leaving it in 4wd all the time, whether you need it or not, is tempting failure of a system not designed for constant use.
That's the part that I have a hard time with. If that is true, then anyone who thinks they need 4wd all or even most of the time, is asking for trouble and has possibly purchased the wrong type of machine.
I suspect that all the people who have made this claim have way more tractor experience than me, especially with 4wd ones (naturally). But when I went to research and buy this tractor no one said at the dealership that the 4wd system was somehow less durable than all the rest of the tractor. The manual does not suggest limiting its use in any way, in fact, it may not even say anything about pavement.
Bottom line is that some cold hard facts would clear this right up. I'm not arguing with the use it when you need it philosophy, I'm concerned with the weak link idea.
/ 4x4 Question #33
I have never hear of anyone ever having tractor problems from using their 4X4 capability. I personally avoid "roading" the tractor in 4X4. Don't know if it matters as much as with my truck but don't need 4X4 on pavement when transiting from a to b. If traction is bad enough to recommend 4X4, such as in winter, then there is enough slippage to avoid stressing the mechanicals.
I find that sharp turns in 4X4 tends to tear up the surface you are manuvering on way more than in 4X2 so if that is an issue (on a putting green or whatever.) Where it matters that you tread lightly, consider 4X2 unless you really need to put some HP to the ground.
Anyone here really think it neccessary to constantly be shifting in and out of 4X4, in just when really needed and out when not? My tractor maint guy (damned good mech) and the Kubota manuals don't think there is a problem with the way I do it. I'd be more concerned with the wear caused by constantly shifting in and out than using it.
Of course if the subject tractor is some off brand light duty looks sort of like a tractor that has something that kinda acts like 4X4 then there are probably several other concerns about robustness as severe in nature as the 4X4 issue. If I were afraid that my tradctor was about to self destruct at any time just doing what it was designed to do, I'd be looking for another tractor that didn't need diapers and a nanny to change them.
Most CUT can do in 4X4 the work that a 4X2 tractor needs about 50% more HP to perform (generalization/rule of thumb recommended to me by several sources.) Said another way you can get by with a smaller less powerful tractor if it has 4X4. If you use your tractor to anywhere near its capacity you will be hampered by wheel slipage much more if you run in 4X2.
I personally find having to stop to shift gear ranges on my hydrostat to be a pain, yet transiting from the bucket filling location to the dirt using location would be painfully slow in mid or low range which is used to fill the bucket. It makes sense to me to shift to the gear best fitted to the work and suggest that this IS NOT the same thing as 4X2 vs 4X4.
I need 4X4 to fill the bucket nicely much of the time but could manage to drive from a to b (some of the time) in 4X2, and might, if someone could offer a good rationale as to why switching back and forth is sufficiently advantageous. I see no evidence offered from factory manuals, factory reps, or maint mechs. (Kubota, I haven't a clue about other brands but have heard rumors that there are other robust brands as well.)
We all have our opinions, justified and backed by fact, experience, informed sources, or perhaps just some personal idea we happen to like with nothing to back it up but a restatement of our personal whim. I prefer taking guidance from the former not the latter. Still, I try to keep an open mind and would love to be shown the true path if anyone could cite some sources. If I'm living in a fool's paradise I'd rather be straightened out than erroneously operate in a destructive or non productive manner.
Pat
/ 4x4 Question #34
I probably shouldn't even say anything because I'm such a tractor rookie, but because I'm such a rookie I've been reading my owners manual quite a bit. In fact, Shirley laughs at me because it's become bedside reading material for me. :eek: For my 3510 Mahindra, the manual says that it is most/more efficient in 4wd. For the record, I have very little flat land. I just keep mine in 4wd all the time now (I wouldn't do that on pavement..).
/ 4x4 Question #35
patrick_g said:
Anyone here really think it neccessary to constantly be shifting in and out of 4X4, in just when really needed and out when not? My tractor maint guy (damned good mech) and the Kubota manuals don't think there is a problem with the way I do it. I'd be more conceerned with the wear caused by constantly shifting in and out than using it Pat
I'd say if you were having to shift in and out of 4WD constantly, to leave it in 4WD. Ain't know need in wearing out a good shifter. But that ain't what's been said here :p
/ 4x4 Question #36
You guy's-n-gal's must be really bored, you just argued this subject a few weeks ago.
/ 4x4 Question #37
Yeah but you have to consider, for some people, it's never enough ;)
/ 4x4 Question #38
Another newbie/inexperienced comment here, so take it for what its worth. If you need 4wd, use it. By need I mean loosing traction - heavy FEL work, plowing, discing, steep hills, ect. When I mow fields (borrowed 45hp CT) I leave it in 2wd. No need for the extra traction provided by powered front wheels. Would it hurt to use 4wd all the time? I dont know. If I was doing work that caused the tires to loose traction or potentially loose traction (steep hills, ect.) then IMO 4wd would be appropriate.
/ 4x4 Question #39
Henro, feels that he needs 4 wheel most of the time. Theres nothing wrong with that. Others don't feel the need, thats OK too. I run my tractors in 4 wheel most of the time,because I feel the need. My 870 has 2090 hours and have not had any problems with the front end.
/ 4x4 Question #40
Just last week a friend of my brother took his JD 4410 tractor out of 4 wheel drive because he did not want to forget to take it out when he got onto the blacktop. As he was traveling on a logging road headed off a hill it broke traction and slid about 50 feet, hit a dirt bank and rolled, coming to rest on its side. Just shows what can happen when someone thinks they don't need 4 wheel drive.
2008 SHOP OF (A65643)
2006 CASE 430 SKID STEER (A65053)
2006 CASE 430 SKID...
1970 Freehauf Lowboy, 20' Deck with 3' Dovetail (A62679)
1970 Freehauf...
New 5400LB, Rachet Binders and G70 Chains (A62679)
New 5400LB, Rachet...
RoadTec RP190 (A63689)
Buckhorn Poly Bulk Feed Box (A66408)
Buckhorn Poly Bulk...
