4WD Compact vs. 2WD Utility
/ 4WD Compact vs. 2WD Utility #21
One advantage of 4 wheel drive is you may be able to get along without chains for snow plowing if that is an intended use, especially if you have ag tires. Chains can be a clearence problem with fenders and front tie rod ends.
/ 4WD Compact vs. 2WD Utility #22
Tractors only had 2WD for years and years before 4WD. Farmers got by just fine then.
Eugene
/ 4WD Compact vs. 2WD Utility #23
Before tractors there were horses. Farmers got by just fine with them too. Have fun.
/ 4WD Compact vs. 2WD Utility #24
If you are looking for a tough, older tractor with 2wd, 3PH, around 45 HP, you would be hard pressed to beat a diesel Farmall 504. We have 2 that have been in the family since they were new. They are like the "Energizer Bunny" of tractors.
/ 4WD Compact vs. 2WD Utility #25
go with 4 wd! anything is better with 4 wd. amazing the difference !!!!!! try them out.
/ 4WD Compact vs. 2WD Utility #26
Hey Robert,
I'd sure hope so!!
Tim,
Do not leave out the David Brown tractors especially the later ones 885,990,Case 1190,1290,1194,1294.
UNUSED IRANCH IRTPL 10000 LB TWO-POST CAR LIFT (A64281)
UNUSED IRANCH...
Adams High Clearance 5 Ton Spreader (A63688)
Adams High...
2008 Ford E-450 Super Duty Ambulance (A61573)
2008 Ford E-450...
2013 Dodge Charger Sedan (A61574)
2013 Dodge Charger...
2017 Ford Explorer AWD SUV (A59231)
2017 Ford Explorer...
2012 WESTERNSTAR 4900FA (INOPERABLE) (A63569)
2012 WESTERNSTAR...
