48x39x14 shop build
   / 48x39x14 shop build
How warm is comfortable varies by person, and perhaps time of day, and activity.
You can sleep in a 60f room just fine. Sit in one and watch TV for 3 hours and you won't be comfortable.
Water temp of radiant is one thing - but how much radiant material is in a room matters as much or more as well. A smaller room gets less than a bigger room of course, but does it in the floor do as well under furniture? You'd not run it under the tub or kitchen cabinets, right? So what about a bedoorm or living room? Under the room perimiter would be under the tv, sofa, etc.
Oh, I meant to discuss this radiant thing. I think my shop temp might be more stable if it was full. The heat soaking items would help maintain temps. Kinda like they say about a freezer. Takes less energy to keep it at freezing temp if it's full rather than empty.
Again, in regards to piping under things. The things,that absorb the heat are what's radiating that comfort to me. There's no efficiency loss if the floor is warm under the sofa.
Friend of mine has cattle and a mechanic shop. His shop and house are floor heated. He says if you come in the house and are cold, grab a blanket and lay on the floor. Within a couple minutes the cold is gone. Totally the opposite of any other heat type.
   / 48x39x14 shop build #232
I replaced radiant (hot water radiators and baseboards) with forced air in my house.
More dust? slightly. Dust is still in the house, just with radiant not being blown around as much I guess. the filter traps stuff that with radiant is laying about somewhere.
For heat-rise, say, taking a 65d room and making it 72d, nothing works like forced air. HOWever, my studio is not used much in the winter so I keep the temp there about 55. when I need to work in there I"ll turn it up to 70 - it gets working-warm in 10-15 minutes..BUT - furniture and such is still cold to the touch, the 55F it's been kept at.
I've nto lived/worked ina radiant heated floor to know how that is to actually live with - is it warm?
And does efficiency differ by type of heating? Forced air I can turn back when I'm not there and heat it bck up quickly..the radiators never did very well at that. So it's more comfortable to keep it warm 24/7.
And if the tools/floor/tables are heated by radiant, great - but if you have to wear a coat due to air temp it's not comfortable (IMO).
And if the slab is hot, it's unlikely to heat up quickly..so it's going to need to be kept warm 24/7..not efficient to warm an empty space.
And if takes 50,000 BTU to warm/maintain temps, does it matter what the method is? Cost wise to make the heat will vary by fuel, but 50k btu is 50k btu. Now can a radiant heater FEEL more comfortable over force air (or vice versa) with less BTU being used for heating?
THAT is the question
No doubt radiant is better suited to occupied structures... like schools, offices and such or with someone home day and night.
I had to laugh with my ceramic tile wood fired oven... magnificent radiant heat as well as efficient and safe... my friends would say crank it up... I would say takes about 3 to 4 hours to make a difference... now, if someone is home... twice a day and the home is always nice even on the coldest days... once a day for simple cold... but no such thing as cranking it up.
   / 48x39x14 shop build #233
Been reading along and have some pointers/info from my experience the past 5 winters in my shop and 4 in the house, heated the same as yours - via a tankless heater. Sorry about the length but I have some significant learnings...
The first winter was pretty great (shop only). Towards the end of the season I started to hear the heater buzzing/vibrating when it was running and it got pretty bad. In my research I learned this was cavitation - where the water is actually boiling in spots. This is not good for the heater at all. I called the place that I got the supplies from and he suggested that the regular 15 psi was insufficient for a tankless heater and to take it up to 25-30 psi. He was right (sort of - I'll get to that next). Now to take the system up in pressure, you first need to take the pressure off the air bladder expansion tank, and pump it up to the higher pressure you are targeting. Then top off the system and flush the air from the lines, then pressurize.
Anti-freeze. I did not start with anti freeze, just water. I started to get concerned that if the heat went down or something happened, the system might freeze up. That would be super bad. So I calculated the system total volume and then pumped in enough radiant system anti freeze to make up approx half of that while pumping out water. Shooting for the 50/50 ratio. This was when the cavitation problem really became pronounced and I made the call I described above.
Yrs 2-3-4 saw some cavitation occurring but it was much milder than before. I also ran into problems with the little filter plugging up and choking flow so I had to take it down to clean that out a few times over the heating seasons. Every time you do this, it is the same old top off, flush air, repressurize routine. That gets old. Then something else happened in year 4 that woke me up. A little background is needed: I have radiant in the shop and house, and a tankless heater for the house domestic HW. The shop unit is 95% efficient but the house ones are 97% and the 2 in the house are identical to each other (1 on radiant, 1 on DHW). The DHW started leaking and it turned out the be the heat exchanger. Well within warranty but I was not pleased and puzzled. The manufacturer (Takagi for all these) had good support and sent me a heat exchanger but I had to install it. That was VERY painful as everything has to come out to swap that, plus a lot of wiring. Thank gawd for their detailed instructions with photos. So he sent it as a "goodwill" gesture at the start, and that seemed odd. He wanted me to send back photos of the underside of the HX after I got it out. There were blackened areas on it and he said that was from hard water and that it did not fall under warranty, but they would allow me this one time freebie, but not again. So the water... When we moved in, i had not yet put a softener in thinking I would get to it soon. Well within 2-3 months, shower heads and valves were plugging up with hard water deposits. Got a testing kit and my hardness came in around 26 grains. Well I got a softener in shortly after and so we had run hard water for only about 4 months total. That was enough to kill this heat exchanger a couple years later. Hmmmm.... the other 2 heaters for house and shop radiant were filled with hard water...
So the house radiant had started making cavitation noises also, so before the start of this heating season, I did a descale on the 2 radiant heaters. AHA! Now all of a sudden everything is nice and quiet. So i believe the cavitation is a combination of the scale build up and the initial low pressure.
So the lessons from this are 1. NO hard water! Or you need to descale from time to time. 2. 25-30 psi is a much better pressure for a radiant system on a tankless vs the standard radiant pressure of 15 psi.
I find it works great for heat. Always nice and comfortable. The floors are never really very warm, except in some spots, like near the manifold. The thing I really notice with it is that the floors don't feel warm, but they never feel cold in bare feet. If I had the floors warm enough to feel significantly warm to the touch, it would be a sauna in here, as the house is well sealed and insulated. The only real downside is that drilling into the shop floor to mount things is pretty much a no-no. I tried to scope it all out with an IR camera one time, but could not tell well enough where the lines were.
   / 48x39x14 shop build #234
Some photos of my shop setup. 2 zones - 5 loops on one side, 4 on the other, ~2600 sf total. The shop is 32x80 with the 2 zones split about 32/48 on the length:
The house is zoned pretty much by room. I lost 2 zones during construction, which was very annoying. One was me being stupid and I screwed into a tube after it was VERY inaccessible. the other one i have no idea what went wrong, but it would not hold air pressure after i got it all together. I think there are now 12 functioning zones in the house. I put down 2x sleepers on the main level and poured 1.5" concrete over the tubing, then an additional layer of subfloor over that
Main floor tubing:
   / 48x39x14 shop build #235
Been reading along and have some pointers/info from my experience the past 5 winters in my shop and 4 in the house, heated the same as yours - via a tankless heater. Sorry about the length but I have some significant learnings... <snip>
Thanks for the write up!
   / 48x39x14 shop build #236
I had hot water radiant heat and found out, long storey, that it was installed incorrectly - it needed an 'idle loop' - if the pump shut off the heating elements/exchanging would overheat unless the water kept circulating. Bad install, 2 other companies, regional manufacturer rep and one from themain office all came and tried to fix the issue...NONE of them saw the missing loop...yet it's in the manual for installation...which after the third failure out of warranty repair guy pointed out right away...
So for heating (based on that furnace, 2 others I've bought, estimates on all those new systems) the level of knowledge and expertise in the heating world is VERY VERY VERY low.
Also, doing research on heat loss/gain and efficiency I found out NOBODY has tested, scientifically, ANYTHING. You can get MPG estimates for cars - they test for that in a standard way. As for well, will oil, natural gas be cheaper to run? Will forced air or radiant be cheaper to run? How much savings will a 97% vs 95% vs 80% be? If I run a heat pump, how much will I save on energy?
This info does not exist. anywhere.
What size furnace do you need? (BTU)? I can find the formulas and do the math - and almost every salesman will try to sell you something 50-100% larger.
And apples are not all apples. I have an LG 'mini split' heat pump and it will put out heat to below zero. The heat pump on my main system gives up the ghost about 37F. HUGE difference in capability. Yet both are heat pumps...
Dstig1, thank you very much for taking time to share your experiences. I too have hard water but not sure what it tests. My shop heat is using water straight from the system with no treatment. My pressure regulator is set at 15psi. My heater water temp is set at 115F.
I will use a water softner in the house project.
If you mentioned it and missed it excuse me. Are you using Boilers or Tankless Water Heaters? What temp are they set on?
   / 48x39x14 shop build #238
These are all tankless
Shop radiant - 120F
House radiant 130F
House DHW - 140F
I started the house radiant at 120F but was having low flow issues (maybe also related to the hard water) so i ended up bumping it up 10 deg as pretty much the only lever i had left to pull on. It worked.
I wonder if systems using boilers operating in the 160-170 range using hard water would have even more problems?
   / 48x39x14 shop build #240
Ive had a little exposure to in-floor radiant heat, as my friend the beeman has it in the floor of his new section of his building, about 50'x100' wood shop, and 20'x100' lobby/commons area/lunch room. Powered by wood fired boiler/heater. My dad helped design and install the original system about 15 years ago, I helped maintain it and modified a few things when I worked for him about 5 years ago, but its been a reliable system that he's quite happy with. But this is a commercial situation, business use, heating about 10k feet, all with wood fired boiler, supplemented by a wood stove in the older section.
Ive been trying to absorb what you all have shared, and hope I can use the info someday.
Richard, how's the house project coming? Do you have a thread on it alone? I havent noticed one, but read your posts in other threads that mention it... I'm sure winter weather is slowing down progress.
2008 Volkswagen Passat Sedan (A51694)
2008 Volkswagen...
NEW Wolverine Skid Steer Trencher (A53002)
NEW Wolverine Skid...
New Land Honor Heavy Duty Plate Compactor (A53002)
New Land Honor...
2004 FORD E350 MECHANICS TRUCK (A52576)
2004 FORD E350...
(1) HD 24ft Free Standing Corral Panel (A51572)
(1) HD 24ft Free...
BUYERS PREMIUM & PAYMENT TERMS (A53426)
BUYERS PREMIUM &...
