Buying Advice 48" or 54" deck?
/ 48" or 54" deck? #1
jbjgold
I have 1.5 acres to mow, mostly hilly. My front lawn has a 25 deg. pitch while my back is around 5 deg.
I have two quotes on a 530. One is with the 54", the other with the 48".
I alternate cutting the front lawn, one time up and down, the other time side to side. I now have a 325 with a 48" deck. Should I stick with the 48" or is it worth the extra $$$ for the 54" deck?
/ 48" or 54" deck? #2
I like the 54" in most ways,gets closer to trees ect.,but on my hills it does scalp some.
/ 48" or 54" deck? #3
Our 425 has a 54" deck and it worked great. We got the 62" on our 2305 and liked that even better.
/ 48" or 54" deck? #4
I would choose based on clearance (tree and immovable objects) and how smooth the lawn is, any abrupt changes in contour and you can easily scalp or miss a depression. Otherwise a 54" deck will cut faster eliminating a few passes.
/ 48" or 54" deck? #5
I would go with the 54", it does make more than a noticeable difference in time reduction. I have a 54" deck on my GX255, works great. I am cutting about 1.5 acres of grass too. Even though I typically cut with my 3520 and the GX255, I have done the whole thing with the GX255 - when the 3520 was sent to the shop for a warranty fix.
/ 48" or 54" deck? #6
While I can not argue with any of the previous comments, there is another consideration worthy of merit.
An x500 series can be transported in the bed of a full size pickup weth a 48" deck. I find this benefit worthy of consideration especially if you have any need to assist church/family member too far to drive tractor etc with lawn care.
Please note that it is tight, but my x500 would go right into the bed of my F series truck....deck lightly scraped both wells in bed but did not remove spray on liner or crease bed.
Just a thought.
/ 48" or 54" deck? #7
I went with the 48" on my 534 because the 54" would not fit through the door of the shed I keep it in...
/ 48" or 54" deck? #8
Just a thought.
We bought a 5x8 tilt bed trailer to haul ours on as I really don't like driving anything up a ramp to the back of my pickup.
We later went to a 6x12 when we got the BX and JD2305, but kept the 5x8 for use behind our Rhino and ATVs.
2010 HINO 268 4X2 S/A NON CDL 26FT BOX TRUCK (A59912)
2010 HINO 268 4X2...
Oxy-acetylene Torch and Regulator Rig (A63689)
Oxy-acetylene...
2015 John Deere 310SL 4x4 Extendahoe Loader Backhoe (A61572)
2015 John Deere...
2016 Volvo VNL T/A Sleeper Cab Truck Tractor (A61573)
2016 Volvo VNL T/A...
Yamaha Golf Cart (A57149)
Yamaha Golf Cart...
Sakai SV505 (A60462)
