Buying Advice 48" or 54" deck?
/ 48" or 54" deck? #1
jbjgold
I have 1.5 acres to mow, mostly hilly. My front lawn has a 25 deg. pitch while my back is around 5 deg.
I have two quotes on a 530. One is with the 54", the other with the 48".
I alternate cutting the front lawn, one time up and down, the other time side to side. I now have a 325 with a 48" deck. Should I stick with the 48" or is it worth the extra $$$ for the 54" deck?
/ 48" or 54" deck? #2
I like the 54" in most ways,gets closer to trees ect.,but on my hills it does scalp some.
/ 48" or 54" deck? #3
Our 425 has a 54" deck and it worked great. We got the 62" on our 2305 and liked that even better.
/ 48" or 54" deck? #4
I would choose based on clearance (tree and immovable objects) and how smooth the lawn is, any abrupt changes in contour and you can easily scalp or miss a depression. Otherwise a 54" deck will cut faster eliminating a few passes.
/ 48" or 54" deck? #5
I would go with the 54", it does make more than a noticeable difference in time reduction. I have a 54" deck on my GX255, works great. I am cutting about 1.5 acres of grass too. Even though I typically cut with my 3520 and the GX255, I have done the whole thing with the GX255 - when the 3520 was sent to the shop for a warranty fix.
/ 48" or 54" deck? #6
While I can not argue with any of the previous comments, there is another consideration worthy of merit.
An x500 series can be transported in the bed of a full size pickup weth a 48" deck. I find this benefit worthy of consideration especially if you have any need to assist church/family member too far to drive tractor etc with lawn care.
Please note that it is tight, but my x500 would go right into the bed of my F series truck....deck lightly scraped both wells in bed but did not remove spray on liner or crease bed.
Just a thought.
/ 48" or 54" deck? #7
I went with the 48" on my 534 because the 54" would not fit through the door of the shed I keep it in...
/ 48" or 54" deck? #8
Just a thought.
We bought a 5x8 tilt bed trailer to haul ours on as I really don't like driving anything up a ramp to the back of my pickup.
We later went to a 6x12 when we got the BX and JD2305, but kept the 5x8 for use behind our Rhino and ATVs.
2012 VOLVO DBL SLEEPER ROAD TRACTOR (A62130)
2012 VOLVO DBL...
FLEX HEADER REEL FOR 20' HEAD (A63291)
FLEX HEADER REEL...
2015 Dodge Charger Sedan (A61574)
2015 Dodge Charger...
Industrias America 435 (A64119)
Industrias America...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
CATERILLAR 299D2 SKID STEER (A64279)
CATERILLAR 299D2...
