4707 minimum width
/ 4707 minimum width #1
Titan123
Cabelas LM75
Looking at a 4707 but I need to reduce the width as much as possible. The brochure says minimum width of 60.3”, but not sure that is correct. Can the wheels really be flipped to obtain that width?
I will have to order one in, but don’t want to trust the brochure. Most other 75-100 up tractors have a minimum width of 72”+ unless you get a narrow/specialty model
/ 4707 minimum width #3
If you are ordering a new tractor, one thing is for sure -- the dealer will find an operator's manual and loan it to you. There may be reason to question the accuracy of the brochures but not the operators manuals. The MF operator manuals show all the possible wheel configurations and give dimensions. Mine for an MF 2660 certainly does. Also, if width is that critical to you, then you should be comparing the width when using various tires because overall width will vary with tire type. I'm too lazy to go find my MF 2660 operator's manual but I think the dimensions they show are taken using Ag tires, R1.
I didn’t realize the manual would cover the width options. Thanks. I’ll see what they can provide.
It does say with the standard 420/85r30 tires. Those are fine for my application.
