Snow 47 or 54 snowthrower for x728?
   / 47 or 54 snowthrower for x728? #1
glgeek
minnesota
X728
greetings,
i am shopping for a x728 this week. i am torn between the 2 sizes of snowthrower.
for the smaller, it seems that i will be driving over the edges of the cleared track with the rear wheels if the path is not perfectly straight. width and track are close.
with the larger, will the 728 handle it OK?
any experiences you are willing to share?
thank you,
geek
   / 47 or 54 snowthrower for x728? #2
I have the 728 with a 47 an it worked great. Did a little running over but no biggie since the unit has down pressure. Also if you get in big deep snow the tractor will throw better with a 47. Just my .02
   / 47 or 54 snowthrower for x728? #3
You can always take less than a full pass with the larger blower and for most snow you will appreciate the larger blower being wider than the tractor wheels. Plus with a hydro tractor you can travel whatever speed is required to do the job.
   / 47 or 54 snowthrower for x728? #4
If you have a lot of drifts where the snow is wind packed, stick with the 47". Sure, you can take smaller bites but the first path has to be 47" and my 2305 with it's 4-wheel drive, Curtis hard cab and ballast box has to work at drifts like this.
If you do any sidewalks, stick with the 47" so the snow blower feet will stay on the concrete.
Gravel driveway? Get the 47"
If most of your snow is the light fluffy kind, and it is on a solid flat level surface, go with the 54"
   / 47 or 54 snowthrower for x728? #5
I have a 47" and do short drives. Works well in tight spaces. Having a wider tractor (Deere 4100) isn't an issue because it is hard to do a 47" cut anyway because the snow will fall to the side, a problem with any size two stage Deere blower. My 4100 wouldn't have enough power for a bigger blower.
   / 47 or 54 snowthrower for x728? #6
I have a X740 and have been running a 47" for a lot of years with various JD's. If you get much snow at all, the 47" will hog down the tractor to where you are only moving ahead at 1/2 MPH and the tractor is really working. I never had any problem with tires running up on uncut snow.
In my opinion, anything bigger than 47" will work with lighter snow, but with much heavy snow, it will just slow you down more.
well, i really appreciate all your responses. i read and reread them all multiple times
i went with the 54".
new X728 on order as of this morning.
my 1995 345 just went down the street with its new owner.
i have no tractor in my garage. i don't know what to do.
thanks again
geek
New/Unused Quick Attach Bale Spear (A57454)
New/Unused Quick...
2011 Toyota Camry Sedan (A56859)
2011 Toyota Camry...
2017 VOLVO VNM SINGLE AXLE DAY CAB (A59575)
2017 VOLVO VNM...
Greenworks Commercial 82V CZ60R Zero-Turn Mower-DEMO UNIT (A56436)
Greenworks...
2015 Haulotte 5533A (A53316)
2015 Haulotte...
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
