46" Snowthrower on 2210
/ 46" Snowthrower on 2210 #1
JDFANATIC
Central Connecticut
JD 2210
46\" Snowthrower on 2210
Trust me guys, I don't even want to think about that white powder that we only seemingly just got over, but I just traded in my 425 for a 2210 and thought it would be best that I tried out everything -- well before November... Well, that was a good decision, everything hydraulic didn't fit, or wasn't the right size or length, but the real test turned out to be the PTo shaft. Now my solution may not be the best or correct one, but it did work. Other posts have alluded to improper PTO shaft lengths, and whether or not that was the front PTO, it doesn't matter. When I went to test out the fit of the PTO shaft from the blower to the intermediate spline/gearbox there was no way it was going to fit. It was much too much too long. I tried every clever solution I could come up with, but nothing worked. Just as I was about ready to go to a weld shop and have the shaft cut and rewelded, I wondered if there was another more creative solution. If you guessed it, that's right, I lowered the front hitch to the ground, and raised the front wheels several inches off the ground. At that point, the shaft easily connected to the intermediate hitch.
Boy am I glad I tried this before white knuckle season set in!
Hope this helps another sojourner.
/forums/images/graemlins/tongue.gif
/ 46" Snowthrower on 2210 #2
Re: 46\" Snowthrower on 2210
Do you have any pictures? I just went from a 455 to a 2210 & have a 47 snowblower that I want to use on the 2210. Did you get get a new front PTO for the 2210 or does the one from the 425 work? Does the quick hitch from the 425 work on the 2210?
Chris
Chris,
I could take some pictures, but have no idea how to post them. /forums/images/graemlins/confused.gif /forums/images/graemlins/confused.gif /forums/images/graemlins/confused.gifUnfortunately only the blower itself will work on the 2210. You will need a new front quick hitch -- BM20921 $500 list (I paid $432), implement drive -- BM20708 $180 list (I paid $155), and front pto kit -- LVB25397 $194 (I paid $168). Also make sure the kit includes two extension hoses and fittings for the blower itself (the new front hitch comes with two hoses of the proper length. Additionally, the new kit comes with a new drive shaft (from the transaxle to the implement drive) and a new drive shaft (that goes from the blower to the implement drive). The way the 2210 drive shafts connects is way different than the 425/445/455 series. Also make sure the kit comes with (in your case) manual OMM147922 J2 for the 47" Snow blower.
/ 46" Snowthrower on 2210 #4
It looks like there is a solution and it will work....you now have a very desireable snow removal machine, and saved a bundle of money retrofitting....
Pictures are always welcome!!
Duc
So how do I post pics? /forums/images/graemlins/confused.gif
2012 CHEVROLET CRUZE CAR (A66091)
2012 CHEVROLET...
HYDRAULIC FLUID TANK (A67714)
HYDRAULIC FLUID...
2016 Kubota RTV X1140 (A65563)
2016 Kubota RTV...
2012 FOR F150 REGULAR CAB PICKUP TRUCK (A66091)
2012 FOR F150...
KOMATSU PC88MR-11 EXCAVATOR (A64279)
KOMATSU PC88MR-11...
Kaufman 47ft. Gooseneck Tri Axle Car Hauler Trailer (A66736)
Kaufman 47ft...
