4530??
/ 4530?? #1
wedge40
Looking at the new website. Looks like they changed the backhoe that comes with the 4530 to a smaller one. I was looking that this tractor because it was the smallest tractor with the largest backhoe. Use to be the 595 BH now it's the 485 BH.. There is a one ton difference in prying power between these two backhoes.
Wedge
/ 4530?? #3
I bet we can still order the 509E, but I am not certain. In theory, a 511 with the "E" kit would fit also. My only concern with the 4530 with a big hoe is if you are on hilly property, the dry disc brakes are challenged with a fully loaded (these things are heavy) TLB going down a steep hill. The 5530 uses wet brakes and also has a bigger front axle.
/ 4530??
Found the problem. The new website is pointing to the wrong spec sheet. If you look at spec sheet for 4530, it pulls the sheet for 4035.
Wedge
