4510 3 pt lift
/ 4510 3 pt lift #1
jwcinpk
Veteran Member
Welfare Capital of the World...KY
2009 Mahindra 3316 HST-2008 Mahindra 7010 cab - 2004 Mahindra 6000 4X4
Well folks I've converted my neighbor from Deere to Mahindra. He went out and picked up a 4510 cab. Now he has a problem. He has a 3 pt scissor lift bale spear that he used with his old Deere. The 4510 won't lift a 1000# roll with the scissor lift. I'm talking about a 3 pt bale spear that is lifted with the 3 pt and then it scissors hydraulically to lift it higher so you can load or unload a trailer. His older tractor was a Deere 1530. Hydraulics are rated close to the same. 9.5 gpm on the Deere and 9.6 gpm on the 4510. I haven't gotten a chance to go inspect exactly what's going on, but am I right to suspect that the 4510 should have the uumph to lift a 1000# roll with the hydraulics?
/ 4510 3 pt lift #2
Does this bale spear act as a 2 point lift off of the lower arms, or is it a true 3 point lift using the top link? It makes a difference. As far as lift capacity is concerned GPM only controls the speed of the lift not the lift capacity. How does the rated lift capacity on the 2 tractors compare. Also some of the manufacturers rate at the end of the arm and others are 24" behind the arm. Once the comparison has been done, I would have the dealer check the PSI at the remotes to make sure the 4510 is up to spec.
/ 4510 3 pt lift #3
Joel,
According to the broucure I got on the cabbed Mahindra's, the 4510's hyd. pump only puts out 9.1 gmp.:eek:
hugs, Brandi
2012 INTERNATIONAL 4300 4X2 S/A 18FT NON CDL BOX TRUCK (A67737)
2012 INTERNATIONAL...
NEW HOLLAND 110TL LOADER ATTACHMENT (A67714)
NEW HOLLAND 110TL...
ALLMAND MAXI-LITE II V (A67714)
ALLMAND MAXI-LITE...
PORTA POTTY (A67714)
2007 INTERNATIONAL 4300 SERVICE TRUCK (A66091)
2007 INTERNATIONAL...
2016 MAGNUM TRAILER MLT6S (A67714)
2016 MAGNUM...
