4510 3 pt lift
   / 4510 3 pt lift #1
jwcinpk
Welfare Capital of the World...KY
2009 Mahindra 3316 HST-2008 Mahindra 7010 cab - 2004 Mahindra 6000 4X4
Well folks I've converted my neighbor from Deere to Mahindra. He went out and picked up a 4510 cab. Now he has a problem. He has a 3 pt scissor lift bale spear that he used with his old Deere. The 4510 won't lift a 1000# roll with the scissor lift. I'm talking about a 3 pt bale spear that is lifted with the 3 pt and then it scissors hydraulically to lift it higher so you can load or unload a trailer. His older tractor was a Deere 1530. Hydraulics are rated close to the same. 9.5 gpm on the Deere and 9.6 gpm on the 4510. I haven't gotten a chance to go inspect exactly what's going on, but am I right to suspect that the 4510 should have the uumph to lift a 1000# roll with the hydraulics?
   / 4510 3 pt lift #2
Does this bale spear act as a 2 point lift off of the lower arms, or is it a true 3 point lift using the top link? It makes a difference. As far as lift capacity is concerned GPM only controls the speed of the lift not the lift capacity. How does the rated lift capacity on the 2 tractors compare. Also some of the manufacturers rate at the end of the arm and others are 24" behind the arm. Once the comparison has been done, I would have the dealer check the PSI at the remotes to make sure the 4510 is up to spec.
   / 4510 3 pt lift #3
Joel,
According to the broucure I got on the cabbed Mahindra's, the 4510's hyd. pump only puts out 9.1 gmp.:eek:
hugs, Brandi
Land Honor Skid Steer Backhoe Arm Attachment (A50515)
Land Honor Skid...
2006 Kenworth T600 Semi (A50514)
2006 Kenworth T600...
(30) 9' Pipe Fence Posts (A50515)
(30) 9' Pipe Fence...
2014 DIAMOND C TRAILER MFG. (A50323)
2014 DIAMOND C...
NEVER USED FECON 74in Deck Mulcher FDM74 (A52748)
NEVER USED FECON...
2012 Chevrolet Cruze Sedan (A50324)
2012 Chevrolet...
