430 loader attachments and ballast
/ 430 loader attachments and ballast #1
HSFarmer
Lancaster County, PA
2001 JD 4300 HST
Anyone use the fork lift attachments for the 430?
Also, anyone have a good design for homemade 3 pt. hitch ballast?
/ 430 loader attachments and ballast #2
I have the JD forks for my 430 loader and have found them useful from time to time--recently in putting a pallet on the forks and raising it as far as it would go and standing on it to use a chainsaw to remove ice-caused broken limbs from many trees. Due to a lack of space when the forks are not mounted, I created three "wheeled trollies" and place one beneath the end of each fork and one beneath the back, turn the forks around and park the bucket on them. For ballast, I usually use a heavy (500#) Rhino rear blade, although sometimes I mount up a rear scoop and fill it with cement bags. Eventually I will create a concrete rear ballast the design for which I found at the following Web site:
http://www.mgsweb.com/tractor/hacker/trweight.htm
Good luck, Mike S.
/ 430 loader attachments and ballast #3
I am very happy with the usefullness of the forks on my 430 loader. Wish I had purchased them long ago. Also, they are very easy to get on and off using the quicktach system JD has for the loader attachments.
(4) Kinze Gauge Wheels (A65640)
(4) Kinze Gauge...
Kohler Gasoline Air Compressor (A64553)
Kohler Gasoline...
2007 FREIGHTLINER BUSINESS CLASS M2 SPREADER TRK (A64277)
2007 FREIGHTLINER...
Ellis Band Metal Saw (A62679)
Ellis Band Metal...
53ft Reefer Trailer, VIN # 1GRAA06267S701883 (A65563)
53ft Reefer...
2019 Mercedes-Benz Sprinter Box 1500/2500 Van, VIN # WD4PE7ED3KT012316 (A65563)
2019 Mercedes-Benz...
