430 deck removal
/ 430 deck removal #1
mtnbiker18
John Deere 430
Hello everyone,
I tried searching on this topic, several ways, but didn't find anything definitive.
Is there a certain order things need to be done? I've managed to get almost everything disconnected, with the exception of the driveshaft from the front PTO shaft. What is the trick to getting it off. It SEEMS to be stuck on. I just bought the GT and want to 'freshen things up'.
Thanks for you help.
Duane
/ 430 deck removal #2
:welcome:
Post a good pic or two of what you are stumped with. Think we can help get you over the hump. ;)
I believe there is a sliding ring that locks the PTO shaft on, and u need to just slide it back a bit to slide the shaft off the splined stub. Some lubrication might be needed, such as PB blaster or WD-40 if hard, caked grease makes it stick.
/ 430 deck removal
Here is what I'm having trouble with.
/ 430 deck removal #4
Have you been able to slide that ring (looks like a donut) back as this unlocks the connection, and lets it slide off the splined stub??
Great pic. :)
/ 430 deck removal
Didn't know to do that. Let me go check and see if i can move it back.
Thanks,
Duane
/ 430 deck removal
Thank you for that bit of information. It came off just as you said it would. Now I can start to refurbishing it.
Thanks again.
Merry Christmas,
Duane
/ 430 deck removal #7
Thanks, and Merry Christmas to you too.
Sometimes these things are easier said than done, so glad it worked for you. There are little steel balls in there that the ring captures to lock the PTO on the shaft.
Post some pics of the process of refurbishing. We like pics and any story helps. :)
2014 International WorkStar 7300 4x4 Altec AA55E 55ft. Material Handling Bucket Truck (A60460)
2014 International...
1996 Sunflower 1543-38 Folding Disk (A63688)
1996 Sunflower...
2023 JOHN DEERE 550P LGP CRAWLER DOZER (A65053)
2023 JOHN DEERE...
Landhonor BH-12-72D Backhoe Skid Steer Mount (A62679)
Landhonor...
2013 Chevrolet 3500 Dually (A62613)
2013 Chevrolet...
2003 International 4300 Flatbed Dump 571557 (A62613)
2003 International...
